Offline
Full Member
« on: October 20, 2012, 05:56:36 pm » |
I am going to install some high power LED's on an FPV Airplane for nightflying purposes. I want to drive 5 3w LED's, and 2 1w LED's with a minimal of power usage as possible, so I think PWM would be the best bet also so I can control brightness. The 3w LED's (White), have something like a 3.2v forward voltage and 750ma current draw at full brightness, the other 1w LED's have similar forward voltage but 350ma current.
I am considering the ULN2803 but I am concerned with heat dissipation as well as PWM ability, so what does everyone recommend? Ultimately I will probably only run these lights 1/4th of their power if not less most of the time except for take-off's and landings.
Logged
Cape Town South Africa
Offline
Edison Member
A newbie with loads of posts, and still so much to learn !
« Reply #1 on: October 20, 2012, 06:15:57 pm » |
What voltage is the battery to supply the LEDs?
Logged
We live in the era of the smart phones and stupid people.
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #2 on: October 20, 2012, 06:17:36 pm » |
I am considering the ULN2803 Don't. For driving high power LEDs you need a constant current supply, resistors do not cut it at these powers. To maximize efficiency put the LEDs in series to match the volts drop to as much as possible to your supply voltage.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #3 on: October 20, 2012, 06:25:43 pm » |
Depending on your battery voltage a buck or boost constant-current drive module would be the most efficient - only fairly slow PWM works with these from my researches, but the Arduino's default PWM is quite slow.
If the battery voltage is 5V you can use a non-switching constant-current drive chip (I've just been looking at the various CAT4101 chips for instance that do this. PWM fast or slow is fine. 5V to 3.2V will waste some power, but the driver is probably cheaper and lighter. Some heatsinking needed though...
For driving several LEDs in series you might need a boost driver, but otherwise a buck driver likely to be most efficient.
Logged
Offline
Full Member
« Reply #4 on: October 20, 2012, 06:51:19 pm » |
My main battery will be a 4 Sell lipo, so battery voltage will be between 14.8 to 16.8 (as the battery drains), though I am open to putting in a separate 3 sell (11.1 to 12.6v). The layout I am planning is 3 of the 3w's upfront to be a headlight, so they can be pwm'd as a group and would be ideal for a series, 2 of them will be mounted on either side of the fuse to light up the wings as well as provide flood and landing light, they could be series too, then there will be 1 1w on each wing tip (red/green). I have been thinking about all of these factors and I know that any sort of linear DC-DC is going to dissipate a LOT of wasted heat and considering the plane is made of foam excess heat is not preferred  .
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #5 on: October 20, 2012, 07:38:14 pm » |
Something like this but more current and cheaper? https://www.sparkfun.com/products/9642Couldn't find a breakout for the ZLED7001 chip (one of the many suitable buck chips - needs support circuitry to work). If want many LEDs all switched then a single DC-DC converter makes more sense to supply them I think.
Logged
Offline
Full Member
« Reply #7 on: October 21, 2012, 02:36:36 am » |
I also found the cat4101 1a
Logged
Offline
Full Member
« Reply #8 on: October 22, 2012, 10:17:58 pm » |
I ended up ordering some NCP3065PG and CAT4101, I will give status update on them once they arrive.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #9 on: October 29, 2012, 02:42:06 pm » |
Does anyone have an eagle part for the STCS2ASPR? If you could point me in the direction even for a PowerSO-10 package that would also be very helpful.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #10 on: October 29, 2012, 03:03:43 pm » |
Or consider making an Eagle library yourself - its not as hard as you might think (tedious, perhaps, hard: no) - there are lots of Eagle tutorials out there to step you through it. You can copy packages and symbols from other libraries (alas that is a bit involved, find a tutorial) too.
Logged
Offline
Full Member
« Reply #11 on: November 07, 2012, 06:19:28 am » |
Ok sofar I am working with the CAT4101 1A constant current sink, for my white LEDs I set the current to 700ma and it runs quite well and use arduino to handle PWM just fine. Now since my design is using a 5v rail and all of these LED's I am using have FV of roughly 3.5 to 3.8v the driver doesn't have to waste much energy on voltage drop so it stays cool, and the led's get warm of course but not unmanageably so. Now what I am considering to reduce component count is to power 2 1 watt LED's in parallel off of one CAT4101, they both can do 350ma so the driver set to 700ma should have no problems handling both in parallel, however since the red LED has a FV of 2.2v and not 3.8 like green, will this cause a current split difference between red and green, and if so how much and how can I calculate that and correct for it?
« Last Edit: November 07, 2012, 06:22:12 am by MatCat »
Logged
Valencia, Spain
Offline
Faraday Member
« Reply #12 on: November 07, 2012, 07:09:20 am » |
Most of the controllers for these sort of LEDs have PWM inputs on the board so it's not a problem.
Logged
No, I don't answer questions sent in private messages...
Valencia, Spain
Offline
Faraday Member
« Reply #13 on: November 07, 2012, 07:10:31 am » |
I have been thinking about all of these factors and I know that any sort of linear DC-DC is going to dissipate a LOT of wasted heat and considering the plane is made of foam excess heat is not preferred  . At least you won't have a problem with airflow...
Logged
Offline
Full Member
« Reply #14 on: November 07, 2012, 07:16:59 am » |
I have been thinking about all of these factors and I know that any sort of linear DC-DC is going to dissipate a LOT of wasted heat and considering the plane is made of foam excess heat is not preferred  . At least you won't have a problem with airflow...  Actually no I won't ROFL, I just did a mounting test as pictured below, zip-ties go through a flattened copper tube to hold the LED star on which makes direct contact with the copper, this is in turn zip-tied to a wooden dowel, which is hot-glued to a piece of foam. Now the LED star stabalizes at 160F when running at full blast (350ma), the back end of the copper as shown get's up to about 140F, and between the wooden dowel and the foam 111F, where the hot glue is doesn't even get above ambient, so I think all is fine.  But my question remains from above, can I drive both a red (2.2v FV), and a green (3.8v FV) which both have 350ma operating capacity from a 700ma constant current sink and have them equally split the current (5v source), or will I need a resistor on the red to keep it from sucking up more current then green?
« Last Edit: November 07, 2012, 07:20:04 am by MatCat »
Logged
