Pages: 1 [2]   Go Down
Author Topic: Looking for advice on driving 3w and 1w LED's  (Read 1384 times)
Cape Town South Africa
A newbie with loads of posts, and still so much to learn !
I think I missed the bit when we went from 10v battery to 5 v supply,    but you could put the red and green in series  ( 6v ) and run them from a pwm constant current current device from the main battery?
We live in the era of the smart phones and stupid people.
Actually the primary system battery is roughly 15v, that would be a lot of wasted heat to linearly lose in voltage drop!  So instead I am going to power the lighting system with a switching regulator that can provide 4A at about 5.2v.  Series would be preferred but the voltage isn't quite enough, I don't know if the UBEC's I have coming are switchable to 6v, if it is I will just run those two in series, there is a .5v drop on the current sink too to keep thought of, that puts the theoretical need at 6.5v, however the green LED is spec'd down to 3.4v, so 3.4v + 2.2v + 0.5v = 6.1, and if the UBEC has 6v selector realistic output will be 6.2, I actually have another 7A UBEC that puts out 6.2, I might just use that one.
Oh another thought on these red and green LED's... The actual LED's will be each on about 1.2 meters of 22 AWG wire, which means in series from + to - there is a travel of about 4.8 meters of 22AWG wire, I wonder what that does to resistance and capacitance, and if it is enough to merit bumping up the total constant current sink to overcome the loss, plus it will all be on PWM so technically it should be able to be a bit higher because of that too, any thoughts?
Manchester (England England)
Online Online
Solder is electric glue
I would not bother about the length it is short enough.
Mind you it will radiate like stink but then you are not going for FCC approval are you.
Valencia, Spain
At these power levels it might drop half a volt along the wire because of resistance. No biggie, but make sure you have enough overhead in the power supply.
All you need to worry about is that is has enough volts to play with.
I hadn't thought of that...  like a giant antenna...  hrm...  any ideas on preventing that?
Valencia, Spain
Shielded wire...?
« Last Edit: November 09, 2012, 01:10:14 pm by fungus » Logged
I will use my SDR and experiment and see if I pick up any odd frequencies from using the lights as is... Mainly RC airplanes have lights so I am not thinking it's going to be a big issues, especially as long as they aren't messing with 433MHz or 1.3GHz hehe.
A question... I am using these cat4101 constant current sink drivers, and I am wondering... SINCE it is constant current, does that mean if I parallel multiple LED's to the driver that each LED will just get LED Count / Current Sink ma of current?  Technically having the LED paralleled means that each LED will see 5v, and the sink will only sink 700ma total as that is how it is set, so if I parallel 2 white LED's that at full power consume 700ma each with a forward voltage of 3.5v onto a 700ma sink, then it should in reality split equally the current allowing only 350ma through each, and dissipating 1.25v x2 to heat (.5v is used by current driver), and continue the pattern regardless of the number of LED's... am I correct in my understanding, and or is there more to understand exactly how I would figure it out properly, thanks!
Pages: 1 [2]   Go Up
