Loading...
Pages: [1]   Go Down
Author Topic: RTC without hardware  (Read 379 times)
Offline Offline
Newbie
View Profile
Hello, I'm new to arduino. I would like date and time stamp into the serial output.how can this be done without any extra hardware. if not possible, please do recommend me any rtc that i can use to do this.
Logged
Central MN, USA
Online Online
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
DS1307
Arduino has no integrated RTC.
Logged
Offline Offline
Newbie
View Profile
Quote
DS1307
I have purchased the DS1307 from sgbotics.
http://www.sgbotic.com/index.php?dispatch=products.view&product_id=366
can i know how must i write the code in order to print the date and time? is there any sample code available?
« Last Edit: December 19, 2012, 12:13:13 am by Jeremytan » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
There is sample code in the Playground:
http://playground.arduino.cc/Main/InterfacingWithHardware%23Communication
Use "Edit: Find on this Page" to find DS1307 in the Time section.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Edison Member
View Profile
Quote
It can be easily done with a timer counting cpu pulses. No need for extra hardware. And you can program in error correction (to compensate for crystal's tempco), making it potentially far more accurate than non-tempco corrected rtc.
Logged
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
The Time library is a software RTC. Additionally, it can be interfaced to a hardware RTC, but this is not required. As noted, without additional hardware, accuracy is dependent on the system clock.
A feature of the ATmega328 et al is a "Real Time Counter with Separate Oscillator", which does require an external 32.768kHz crystal. Using this feature, an RTC can be implemented that continues to run while the rest of the chip sleeps. See the datasheet, sections 9.5, 18.10.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
UK
Offline Offline
Tesla Member
View Profile
I assume that the serial output is going to a PC of some sort and that the output will consist of ascii text.
The Arduino can measure elapsed time but without an RTC or a network interface it has no way of knowing what date/time it is starting from. You could use the serial link to send it the initial date/time, but you'd need to do that every time the Arduino was restarted and to me that does not seem feasible. It is far more sensible to prefix the output with a timestamp on the PC side. What operating system is the PC running, and what are you trying to do with the serial data once it reaches the PC?
Logged
Pages: [1]   Go Up
Print
Jump to:
