Topic: arduino uno usb device (Read 4088 times) previous topic - next topic
strider51
Hi
  I just got my arduino and I am trying to install it. my OS is Win XP.  I am following the windows installation link instructions and when I plug in the USB A-B cable, It detects it as a 'USB device'  not a 'Arduino Uno'. when I acknowledge the bubble, the 'new hardware installation'  dialog comes up and says it is just a USB device.  If I look at the Device Manager, it does not show up in the COM & LPT secion but in the USB devices. I confirmed that it is the Arduino because I can unplug it and it goes away.   I tried using the 'new hardware installation'  dialog procedure but when I went to the arduino driver directory, it would not acknowledge a driver there. Some blogs I searched said to try updating the hardware in the device manager under the 'USB device' entry but that would not acknowledge a driver either. I am at a loss of what to do next, Can anyong help with this. Thanks.
spcomputing
Try this Modified IDE:
http://arduino.cc/forum/index.php/topic,73748.0.html
strider51
    Thank you for your response but unless I am missing something, I don't think it is going to work.
The only COM port that my PC sees is COM 1 which is the one with the original RS-232 serial port.  The test you gave wants a terminal program which you will have to enter a COM port number to communicate with the arduino and there isn't one.  so unless I am missing something, I am going to need more info on what I am doing wrong. The only thing that I could see which are communication lines are the ones marked 0-Tx and 1-Rx. Does the loop-back test use these for a serial port? if so, I would have to make a cable with a connector. thanks.
spcomputing
I am so sorry, my copy buffer did not copy what I wanted  :smiley-red:
Try this one:
http://arduino.cc/forum/index.php/topic,118440.0.html
strider51
  thanks for getting back to me. Can I trust this download?   I have had several viruses introduced in the last 2 years from downloading different utilities.
spcomputing
Many members (Including myself) have downloaded this with no issues.  Just click the download for the setup_Arduino_ERW_1.0.1i_20121020.exe file.  I will talk to the author and see if he would be interested in moving it to GiHub or something.
strider51
   The only reason I ask is Web-Of-Trust gave the download site  a red indicator saying it was  untrustworthy.
spcomputing
Try this then ;)
https://github.com/downloads/eried/Arduino/setup_Arduino_ERW_1.0.1i_20121020.exe
spcomputing
Yeah, I just got the PM from eried that he moved a copy to Github...
strider51
    I downloaded and installed the software for the enhanced IDE, went thru the whole process and loaded all the different arduino drivers. I went to the IDE and used the circuit one example. I compiled and uploaded. what was strange is it uploaded but I didn't have it plugged in and it didn't complain. I plugged it in but it still is not recognizing where the arduino port is and it will allow me to still upload. I looked at the tools->serial port and it all it sees is COM 1. according to the
'Arduino Enhanced Release 1.0.1i for Windows' page  it should automatically fix this but I see nothing that it was fixed.
when I plug the usb cable with the arduino, it is also telling me it found new hardware. Is there anything I am doing wrong. I am ready to pull my hair out. thanks.
« on: August 13, 2012, 10:02:03 PM »
spcomputing
Have you tried a reboot after the installation?  Is there another USB port on the PC or do you have a USB hub?
strider51
   I have a wireless USB wifi adapter and a wireless USB mouse, no hub. I did try rebooting but still nothing. It still comes up and says 'new hard ware found, 'USB device' and proceeds to the new hardware setup dialog.  Arduino still sees only COM 1.
any other suggestions?  thanks again for any help. I appreciate it.
spcomputing
Do you have another USB AB cable (Printer cable, etc)?
Secondly, can you get me a screenshot of what you see when the device wizard takes off and you manually select the driver, when you get to the "driver folder" do a <Cntl+Alt Prt Sc> and bring up "mspaint" paste it, save it and attach it (Additional Options...)to this thread.
strider51
   I did try another USB cable but that didn't help.  I am going to get another one from work and try it out. After work, Ill get those screen shots. thanks.
