Topic: arduino uno usb device (Read 4093 times) previous topic - next topic
strider51
    here is the screen shots. It was weird. when I came home I plugged in the arduino cable and the balloon for new device 'found said 'Arduino Uno' but quickly went to 'usb device'. when I looked at the device manager, it had the 'usb device' in the
'COM and LPT' but it did not say anything about Arduino Uno.  As you can see from the one screen shot, when I went to find the driver the 'OK' was greyed out. hope this helps. Thanks again.
spcomputing
What happens when you uninstall the unknown device?
strider51
   I think I fixed it and I didn't try this before was because the enhanced version said it will setup the port automatically if it couldn't connect. I though when you installed the enhanced version it automatically put in the drivers also. When I plugged the usb cable again, and got the 'new device found'  dialog , I pointed it to the folder where the enhanced IDE version drivers were, not the original ones I had unzipped.  Why there were no drivers there, I don't understand. that is why in the screen shot I sent you it didn't find anything.  Once I installed the drivers from the enhanced version, it worked! Thank you again for all your help, I appreciate it.  hopefully this is fixed now and I won't have to post in this thread anymore.  See ya around the forum!
spcomputing
Whew...I was running out of ideas  :smiley-eek:.
Hope it continues to work out for you.
