Loading...
Pages: [1]   Go Down
Author Topic: BitBool Class ( boolean array ), upto 16000 elements on UNO.  (Read 722 times)
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
This is a small class designed to lower SRAM usage for bool arrays. Values can be inspected or assigned using standard array sub-script operators ( '[]' ), the code below is the library, and underneath that is a sample sketch of generic array usage, it contains a #define called USE_STANDARD_BOOL which if uncommented will use a standard bool array, otherwise a BitBool array is used. The internal data is accessible allowing manipulation of bits and bytes.
Some usages may be: large sets of bool flags, LED patterns/shift data.
This is only a basic implementation, if anybody has a need for some form of shifting / conversion /any other mod, please post your ideas.
BitBool.h
Code:
#ifndef HEADER_BITBOOL
  #define HEADER_BITBOOL
  #include "Arduino.h"
  template< size_t _Count >
    class BitBool{
      protected:
        struct BitRef{
          BitRef( uint8_t &u_DataRef, const uint8_t u_Idx ) : u_Data( u_DataRef ), u_Index( 0x1 << u_Idx ) { return; }
          operator const bool() const { return this->u_Data & this->u_Index; }
          const bool operator =( const BitRef &b_Copy ) const { return *this = ( const bool ) b_Copy; }
          const bool operator =( const bool &b_Copy ) const
              if( b_Copy )  this->u_Data |= this->u_Index;
              else          this->u_Data &= ~this->u_Index;
              return b_Copy;
          uint8_t &u_Data;
          uint8_t const u_Index;
      public:
        enum{ BitCount = _Count, ByteCount = ( BitCount / 0x8 ) + ( ( BitCount % 0x8 ) ? 0x1 : 0x0 ) };
        BitRef operator []( const uint16_t i_Index ) { return BitRef( this->u_Data[ i_Index >> 0x3 ], i_Index & 0x7 ); }
        uint8_t u_Data[ ByteCount ];
#endif
Sketch
Code:
//#define USE_STANDARD_BOOL
#define MAX_ITEMS 100
#include <BitBool.h> //use "BitBool.h" if file is local, or remove include and copy class directly in.
#ifdef USE_STANDARD_BOOL
  bool b_Array[ MAX_ITEMS ] = { true, true, true };
#else
  BitBool< MAX_ITEMS > b_Array = { B00000111 };
#endif
void setup() { Serial.begin(9600); }
    bool b_TempCopy = b_Array[ MAX_ITEMS - 1 ];
    //Roll items up.
    for( int i_Index = MAX_ITEMS - 1 ; i_Index ; --i_Index )
      b_Array[ i_Index ] = b_Array[ i_Index - 1 ];
    b_Array[ 0 ] = b_TempCopy;
    //Show contents.
    Serial.print('[');
    for( int i_Index = 0 ; i_Index < MAX_ITEMS ; ++i_Index )
      Serial.print( b_Array[ i_Index ] ? '#' : '-' );
    Serial.print("]\r\n");
Cheers
« Last Edit: October 22, 2012, 03:54:07 am by pYro_65 » Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
        byte b_Data[ ( _Count / 0x8 ) + ( ( _Count % 0x8 ) ? 0x1 : 0x0 ) ];
Different data-types?
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
For what it's worth, I prefer something that looks more like rounding...
        byte b_Data[ ( (_Count + 0x7) / 0x8 ) ];
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Code:
#else
  BitBool< MAX_ITEMS > b_Array; = { B00000111 };
#endif
Quote
Topic_128407:8: error: braces around initializer for non-aggregate type 'BitBool<100u>'
...which compiler version are you using?
Logged
Offline Offline
Edison Member
View Profile
WWW
I agree that the names should match, I have extracted this from a larger library I plan to release once the Due is here, so artifacts have crept in. Also I assume you do already know 'byte' is simply an alias for uint8_t.
And as far as sizing the types, its done in compile time, and I don't believe your method is any more intuitive. I have my own style of writing expressions, I think it is  more of a personal preference thing.
I'll edit the code in a sec, another artifact... done.
b_Data cannot be private.
Original code is fixed now.
Oh and I'm using the Arduino IDE, nothing special ( not relevant now as it was my code error ), thanks for the find.
« Last Edit: October 22, 2012, 03:27:05 am by pYro_65 » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
16000 elements ??
Have you tried your class in PROGMEM?  You could have a really big bitarray - although readonly,  e.g. 25KB ==> 200.000 fixed booleans.
What to do with it?
- for games a fixed bit array (2 dimensional) could hold a playing field e.g. think minesweeper
- a spelling checker (Bentley in Programming pearls), that used a hash function that mapped strings on a bool array. Every bit indicated right or wrong.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Edison Member
View Profile
WWW
Hmmm, I'm not sure, I'll have to do some investigation on making it compatible, but as it stands I don't think it would work, needs a way to retrieve the data.
You have given me some more ideas anyway. I also have a class for dealing with PROGMEM types which may be better for this type of thing.
Logged
Pages: [1]   Go Up
Print
Jump to:
