Pages: 1 2 [3] 4   Go Down
Author Topic: Rfid Door Lock  (Read 1498 times)
Manchester (England England)
Online Online
Solder is electric glue
is the middle pin the gate
No it is the drain.
Look at the data sheet, the last page.
Lay it flat on its back with the hole at the top.
Left pin Gate
Middle pin drain
right pin source
Melbourne, Australia
Shannon Member
Lua rocks!
Whats the IRL234N and how does it connect up
IRLZ34N - that's a Z not a 2!
which website are you on and which data sheet
UK
http://www.irf.com/product-info/datasheets/data/irlz34n.pdf
Straight from the horse's mouth.
Espoo, Finland
"Oops, try again..."
Pick one.
http://search.datasheetcatalog.net/key/IRLZ34N
Philips has the easiest for you...
Cheers,
Kari
« Last Edit: October 23, 2012, 03:46:22 am by GaryP » Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
Hi Nick
How many k or ohms the resistors worth
UK
How many does it say on the diagram?
Hey
Check the schematic on page 1
Espoo, Finland
Components are named, which one is the problem? R1 could be missing something, maybe author would check the correct value. Or it could be just 10.
Bobby,
Be more specific with your questions.
Cheers,
Kari
Shannon Member
Lua rocks!
It's 10 ohms.
10 on its own is 10. (What do you think it meant?) If you go 10 meters that is 10 meters. If you go 10K meters that's 10 kilometers. It's pretty straight-forwards.
Shannon Member
Lua rocks!
Let me ask you a question. R2 is labelled 10K. Do you think that is 10K ohms? Or if not, what do you think it is? I'm interested.
Hi Nick will the system work with this here is the link
Link: http://www.ebay.com.au/itm/Atmega328P-Mega-328-Arduino-compatible-UNO-2011-USB-cable-00960-/251168841798?pt=LH_DefaultDomain_15&hash=item3a7ad46046
Whats R1 then
Gosport, UK
Whats R1 then
See reply #39.
UK
Gorm deficient
Whats R1 then
It's a r-e-s-i-s-t-o-r
Per Arduino ad Astra
Pages: 1 2 [3] 4   Go Up
