Offline
Newbie
« Reply #15 on: October 23, 2012, 10:54:05 am » |
like this?
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #16 on: October 23, 2012, 11:09:13 am » |
The ULN2003 looks a lot better. Now the matrix is not wired like the data sheet is it. The data sheet shows pins 9, 14, 12 & 8, 1, 7, 2 all being anodes. These anodes should be connected to the arduino outputs. The data sheet shows pins 13, 3, 4 & 11, 10, 6 as all being cathodes these should be connected to your ULN2003.
Logged
Offline
Newbie
« Reply #17 on: October 23, 2012, 11:19:52 am » |
Ahh i think i finally understand it all! Thank you! Just one last question, what is the advantage/or disadvantage of using a matrix with transistors instead of the IC? It is so great to have such a helpful community!!  thanks
Logged
Offline
Brattain Member
« Reply #18 on: October 23, 2012, 12:03:45 pm » |
Not much, that IC is a darlington transistor array so it already contains the base resistor you would need if you used a normal transistor. It is smaller so there is less wiring up.
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #19 on: October 23, 2012, 01:01:08 pm » |
The LED wiring is off still. Note that the pins are shown as going across the short length of the body. So you may want to plug the chip in across the middle divider.
I have labelled them A1-7 for the anodes, and C1-5 for the cathodes.
A1 is pin 9 A2 pin 14 A3 pin 8 A4 pin 4 (also available on pin 12) A5 pin 1 A6 pin 7 A7 pin 2
C1 pin 13 C2 pin 3 C3 pin 4 (also available on pin 11) C4 pin 10 C5 pin 6
If you look on the bottom of the part you may see a 1 next to one of the corner pins. Plug it in and drive the output pin for C1 high (display pin 13) and for R1 low (display pin 9) - should see the corner LED turn on. If not, rotate the display 180 degrees around and try again.
Logged
Offline
Newbie
« Reply #20 on: October 23, 2012, 02:46:11 pm » |
there are 7 pins on each side of the LED matrix..
Logged
Global Moderator
Offline
Brattain Member
« Reply #21 on: October 23, 2012, 07:24:15 pm » |
The pin numbers I gave above correspond to those 14 pins.
Logged
Offline
Newbie
« Reply #22 on: October 25, 2012, 12:09:34 pm » |
I have built the circuit but the matrix is not working correctly
could you take a look and see if i have made a mistake.
(the resistors are not connected on purpose, was checking if they were limiting matrix too much. BUT are connected during tests)
The results are slightly dim LEDs slightly brighter LEDs, some off.
Logged
Offline
Brattain Member
« Reply #23 on: October 25, 2012, 12:19:34 pm » |
We need to know exactly what it does and what you expect it to do.
Logged
Global Moderator
Offline
Brattain Member
« Reply #24 on: October 25, 2012, 12:27:29 pm » |
Pin 1 on the ULN2003 is the lower left corner? Looks like you have 6 outputs wired up? While there are only 5 cathodes?
Same with the display - pin 1 is lower left? Any chance its just flipped?
How about posting the code you are running?
Logged
Offline
Newbie
« Reply #25 on: October 25, 2012, 12:35:33 pm » |
const int rows[] = { 9, 14, 12, 8, 1, 7, 2 }; const int cols[] = { 13, 3, 4 , 10, 6};
void setup() { for (int c = 0; c < 7; c++) { pinMode(cols[c], OUTPUT); digitalWrite(cols[c], LOW); }
for (int r = 0; r < 5; r++) { pinMode(rows[r], OUTPUT); digitalWrite(rows[r], LOW); } void loop(){ }
« Last Edit: October 25, 2012, 12:38:57 pm by adamedelberg »
Logged
Global Moderator
Offline
Brattain Member
« Reply #26 on: October 25, 2012, 12:37:13 pm » |
LIttle light on the application code here  void loop(){ }
Logged
Offline
Newbie
« Reply #27 on: October 25, 2012, 12:39:45 pm » |
Just really want to get it working first ;P
Logged
Offline
Newbie
« Reply #28 on: October 25, 2012, 01:39:45 pm » |
when i execute that code, this is the result:
Logged
Offline
Brattain Member
« Reply #29 on: October 25, 2012, 05:58:25 pm » |
We need to know exactly what it does and what you expect it to do. I would expect from that code that all the LEDs should be off. What do you expect? As all the LEDs are not off then you have wired it up incorrectly.
Logged
