Okay, one common way to tdo that is to drive all 5 anode hi or low, and pull one cathode, then repeat that for the next 4 columns quickly.
You will define some fonts, Imagine the letter A as a 7 tall x5 wide array with 1 = LED on and 0 = LED off:
1 1 1 1 1
1 0 0 0 1
1 0 0 0 1
1 1 1 1 1
1 0 0 0 1
1 0 0 0 1
1 0 0 0 1
So assuming an unused 8th bit that is always 0, each column could be represented as
01111111 = 0x7f
01001000 = 0x48
01001000 = 0x48
01001000 = 0x48
01111111 = 0x7f
So now you write some code that sends out a byte of data and 1 cathode control bit every 1mS:
void loop(){
// column 1
if (1mS elapsed){
all cathodes off
write anodes with 0x7x
turn on cathode 1
// column 2
if (1mS elapsed){
all cathodes off
write anodes with 0x48
turn on cathode 2
// column 3
if (1mS elapsed){
all cathodes off
turn on cathode 3
// column 4
if (1mS elapsed){
all cathodes off
turn on cathode 4
// column 5
if (1mS elapsed){
all cathodes off
turn on cathode 5
} // end loop
Can you follow that? You are the driving the LEDs for a column at a time, and using persistence of vision to make the eye think any LED can be on at any time.
You can see how this would fit nicely into a loop, then expand from there to have the fonts predefined in an array where you would call up the letter/number in question, then expand from there to have say 3 letters in a 15 byte array and roll along to pick 5 bytes from that array for display (0-4, 1-5, 2-6, 3-7, 4-8, etc) to give the impression of scrolling text, and put new bytes in as needed to go thru your message...
Here's a video of my 8x32 display doing similar:
http://youtu.be/hwYqgyMc5S4Scroll test of 8x32 LED matrix. Can hold up to 233 characters in SRAM. Will be ~40 more once I push 5x8 fonts out to PROGMEM.
