Loading...
Pages: 1 [2]   Go Down
Author Topic: 3.3V inputs & outputs  (Read 3337 times)
Forum Administrator
Offline Offline
God Member
I find plain exciting
View Profile
WWW
"using the ioref pin" means that the shileld uses that pin to power level translators so that the shield can work at 3.3v or 5v seamlessly.
You can look at the schematic diagram of the wifi shield to get an idea on how that's done.
m
Logged
Offline Offline
Sr. Member
View Profile
Actually, the chipKIT Uno32 and Max32 boards based on the PIC32 that are Ardunio compatible seem more compatible to Arduino than DUE.  Most pins on the chipKIT boards have 5V tolerant inputs where the DUE does not.  This means that most Arduino shield will work with chipKIT but not DUE.
Well, not quite so fast. The 5V tolerant go some way to ensuring shield compatibility, but there is still the issue of current limitations on gpio pins. Can the Uno32 source/sink 40mA on a gpio? I haven't looked at a data sheet, but I'd be surprised if this was the case.
But agreed, the 5V tolerant pins addresses one important compatibility issue. So certainly _more_ Arduino shields could be expected to work with chipKIT compared to DUE, but "most" is not a given.
And whether you are porting your 8bit/5V project to Due or something like an Uno32, you will still need to tweak the code in any case.
I think we will see that the Due will be much more suited to new projects, rather than providing an upgrade path for existing 8bit/5V Arduino projects.
« Last Edit: November 03, 2012, 01:29:12 am by pico » Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
Quote
I think most of the 8-bitter projects are done on 8 bits because they were possible on these 8 bitters so leaving the case where one is dying to increase the efficiency the porting of 8 bit projects to this massive 32 bit computing power system would not happen.
I'm basically concerned with the shield use.
Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Pages: 1 [2]   Go Up
Print
Jump to:
