Topic: Seeedstudio GPRS shield question (Read 3794 times) previous topic - next topic
liuzengqiang
Here is the Seeedstudio GPRS shield:
http://www.seeedstudio.com/depot/gprs-shield-p-779.html?cPath=132_134
The wiki page says "Make sure your SIM card is unlocked".
http://www.seeedstudio.com/wiki/index.php?title=GPRS_Shield_v0.9b
What does unlocked SIM card mean? Does one have to get some specially made/hacked SIM card to make it work? I was trying to get a prepaid T-mobile (USA) phone with SIM card to send SMS with the shield. Can someone with experience using this shield give me some answers? Thank you!
liuzengqiang
Has anyone used T-mobile prepaid phone sim card on any GPRS shield? Could you share some experience with me? Thanks.
pylon
If you enter a wrong PIN three times your SIM card gets locked and you have to enter your PUK to reactivate it. If you use your SIM card in embedded environments and make a small mistake in the software you have your SIM locked in no time, that's probably why they explicitly mention it.
You probably first have to ask some questions :).
What does not work? Show us the code you used when it didn't work. Show us the output you get, etc.
liuzengqiang
Thanks. I don't have the shield yet. I want to use it with a T-mobile prepaid phone SIM in USA for short messages. I wonder if that works at all, taking that T-mobile SIM and sticking it in the shield then use AT command to send SMS. I hope someone will say "yeah, I did just that and it works."
vlp_arduino
I've got this shield. It works perfectly: SMS & Data !
vlp
48X24X48X
When you use the SIM on a phone, when you boot the phone up and if you need to key in the 4-pin thingy, then it's considered as locked.
The command AT+CPIN=? will let you know whether it's locked or not.
It's kinda scary if you wrongly write them in the firmware (after 3 times, it's locked).
For a GSM module which I wrote the library for (not SIM900), I omitted this SIM pin code function fearing someone might wrongly enter them for 3 times!
liuzengqiang
Thanks!
What AT commands do you use for data?
liuzengqiang
Thank you! I don't think I saw a pass word screen when I power up the phone. I will surely give it a try when I get the shield.
