Loading...
Pages: [1] 2 3   Go Down
Author Topic: Arduino Due Mini/Nano  (Read 5404 times)
Offline Offline
Newbie
View Profile
This may be a little premature, but does anyone know if an Arduino Due Mini/Nano Teensy sized board is planned?
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Start writing up some requiremets, I'm sure it can be reduced to a smaller size.
- desired size
- desired power sourcing
- desired pinouts
- desired headers
- desired built-in interfacing
- etc.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
I wonder if the 'vanilla version' of the SAM3X8E can be used to make own Arduino-compatible boards, since the Due page says:
Quote
The bootloader is preburned in factory from Atmel and is stored in a dedicated ROM memory.
Would this mean Atmel ships a custom Arduino bootloader with these chips, or does the Due use a standard Atmel bootloader? If the former, will be able to burn a bootloader ourselves?  smiley-confuse
Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
The provided bootloaders are for UART and USB, maybe a few others. They are stored on a small rom with some IAP routines so I don't reckon they have been replaced ( UART is serial comms )
Logged
Portugal
Offline Offline
Newbie
View Profile
Quote
From that sentence and what I've read in the SAM3X8E's datasheet I believe the Due's using "standard Atmel bootloader."
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Is that ROM in the 16U2, or in the ATSAM? There is no external ROM part on the board.
I haven't looked at the datasheet - maybe its access via JTAG or SPI?
Logged
Offline Offline
Edison Member
View Profile
WWW
Its in the ATSAM, the data sheet says:
Quote
16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines
also
Quote
The SAM-BA Boot is in ROM and is mapped in Flash at address 0x0 when GPNVM bit 1 is set
to 0.
So when the bit is set it must be over writable just like a normal ISP/similar
« Last Edit: October 23, 2012, 07:59:25 pm by pYro_65 » Logged
0
Offline Offline
Newbie
n0m1 design
View Profile
WWW
The SAM3A4C and SAM3X4C are the smaller (100pin/256k) cousins of the 144 pin SAM3X8E on the Due.
Being in the same family would make quick and dirty ...
Logged
Offline Offline
Newbie
View Profile
If the vanilla SAM3XE chip like you can order it from Farnell works with own-built boards, I might develop a smaller version of the Due. I developed a variant (actually: a shield) for the 8bit Arduino for use in industrial environments (think ruggedcircuits but better :p ), but boards with the dimensions of the Due or the Mega don't fit in our DIN-rail enclosures.
Perhaps it is possible to minimize the dimensions to something in the range of a Uno by omitting some pinheaders. Then you would have the same number of input/outputs of a regular Arduino, but with the processing power of the Due.
Logged
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
The Teensy 3.0 is now entering general release if you wanted an ARM board in a smaller package than the DUE.  The Teensy is not the DUE, so be sure to understand what it offers and what it doesn't.  Teensy 3.0 uses a modified Arduino 1.0.1 IDE.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Definately an arduino due nano would be very cool smiley-grin.
Logged
Peoples Republic of Cantabrigia
Offline Offline
God Member
Arduino happiness
View Profile
WWW
I have one at home, awaiting torture. I can't tell you how excited I am about these little gems. The teensy is aimed at a much smaller market but I also happen to think that the Due is not only overkill but that it's design misses the sweet spot by virtue of shoehorning a 32-bit architecture into a 8-bit legacy interface. This 144-pin monstrosity seems to have been selected because one could put out a board in a similar I/O factor configuration as the Mega. But IMO they should have broken from past shield designs for the 32-bit architecture to eliminate the possibility of fried CPUs, enable improved I/O interfacing, among other issues.
For me, the 64-pin chip on the teensy offers plenty of I/O out of the box while still being bread-boardable. And the chip is 50% less to buy than the SAM processor on the Due, i.e. about the same price difference as a 328 vs. 1284. And the teensy price vs. Due price reflects that too. I am considering re-designing my DAQ boards around a standard dual pin header for the Teensy. It would eliminate a lot of the complexity from my boards and the CPUs can be re-purposed as needed later. Never mind the on-board RTC, 16-bit ADC (vs. 12 on the Due) etc.
But! There is something to be said for the benefits of older 5V-based legacy devices in terms of their ability to drive signals, etc. in ways that the more modern chips cannot.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
Teensy + headers =
I hope to get some time to try some projects out on it this weekend.
Duane B
rcarduino.blogspot.com
Logged
Forum Administrator
Offline Offline
God Member
I find plain exciting
View Profile
WWW
Guys... this forum is about the Arduino Due...
let's keep in on topic
Logged
Lexington, SC
Offline Offline
Jr. Member
View Profile
WWW
While not a Mini/Nano, I look forward to an ethernet Due.  Phy ethernet and SD card can do some pretty awesome things.  I have a Sam3X-EK at work for a project and the demo is pretty slick with a rich web interface but the demo is based on BeRTOS which doesn't have a large community and has custom drivers.  Atmel just added "native" lwIP support to asf and will add SD card drivers in the next version(November hopefully)
Are the Due drivers ASF-based or from scratch because of licensing issues?
I wonder how the Due firmware would work with the Sam3X-EK, Atmel doesn't even sell the processor(SAM3X8H) on the board.
Logged
"Who left the fridge open?"
-Tugg Speedman
(Scorcher VI - Global Meltdown)
Pages: [1] 2 3   Go Up
Print
Jump to:
