« on: October 23, 2012, 01:32:43 pm » |
This may be a little premature, but does anyone know if an Arduino Due Mini/Nano Teensy sized board is planned?
Boston area, metrowest
« Reply #1 on: October 23, 2012, 02:46:00 pm » |
Start writing up some requiremets, I'm sure it can be reduced to a smaller size.
- desired size - desired power sourcing - desired pinouts - desired headers - desired built-in interfacing - etc.
« Reply #2 on: October 23, 2012, 04:12:26 pm » |
I wonder if the 'vanilla version' of the SAM3X8E can be used to make own Arduino-compatible boards, since the Due page says: The bootloader is preburned in factory from Atmel and is stored in a dedicated ROM memory. Would this mean Atmel ships a custom Arduino bootloader with these chips, or does the Due use a standard Atmel bootloader? If the former, will be able to burn a bootloader ourselves?
North Queensland, Australia
« Reply #3 on: October 23, 2012, 06:24:01 pm » |
The provided bootloaders are for UART and USB, maybe a few others. They are stored on a small rom with some IAP routines so I don't reckon they have been replaced ( UART is serial comms )
Portugal
« Reply #4 on: October 23, 2012, 06:56:55 pm » |
I wonder if the 'vanilla version' of the SAM3X8E can be used to make own Arduino-compatible boards, since the Due page says: The bootloader is preburned in factory from Atmel and is stored in a dedicated ROM memory. Would this mean Atmel ships a custom Arduino bootloader with these chips, or does the Due use a standard Atmel bootloader? If the former, will be able to burn a bootloader ourselves?  From that sentence and what I've read in the SAM3X8E's datasheet I believe the Due's using "standard Atmel bootloader."
« Reply #5 on: October 23, 2012, 07:37:51 pm » |
Is that ROM in the 16U2, or in the ATSAM? There is no external ROM part on the board. I haven't looked at the datasheet - maybe its access via JTAG or SPI?
« Reply #6 on: October 23, 2012, 07:56:40 pm » |
Its in the ATSAM, the data sheet says: 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines also The SAM-BA Boot is in ROM and is mapped in Flash at address 0x0 when GPNVM bit 1 is set to 0. So when the bit is set it must be over writable just like a normal ISP/similar
« Last Edit: October 23, 2012, 07:59:25 pm by pYro_65 »
n0m1 design
« Reply #7 on: October 23, 2012, 10:37:29 pm » |
The SAM3A4C and SAM3X4C are the smaller (100pin/256k) cousins of the 144 pin SAM3X8E on the Due. Being in the same family would make quick and dirty ...
« Reply #8 on: October 24, 2012, 06:24:24 am » |
If the vanilla SAM3XE chip like you can order it from Farnell works with own-built boards, I might develop a smaller version of the Due. I developed a variant (actually: a shield) for the 8bit Arduino for use in industrial environments (think ruggedcircuits but better :p ), but boards with the dimensions of the Due or the Mega don't fit in our DIN-rail enclosures.
Perhaps it is possible to minimize the dimensions to something in the range of a Uno by omitting some pinheaders. Then you would have the same number of input/outputs of a regular Arduino, but with the processing power of the Due.
Ayer, Massachusetts, USA
« Reply #9 on: October 24, 2012, 07:37:21 am » |
The Teensy 3.0 is now entering general release if you wanted an ARM board in a smaller package than the DUE. The Teensy is not the DUE, so be sure to understand what it offers and what it doesn't. Teensy 3.0 uses a modified Arduino 1.0.1 IDE.
« Reply #10 on: October 25, 2012, 03:56:33 am » |
Definately an arduino due nano would be very cool  .
Peoples Republic of Cantabrigia
Arduino happiness
« Reply #11 on: October 25, 2012, 01:11:57 pm » |
I have one at home, awaiting torture. I can't tell you how excited I am about these little gems. The teensy is aimed at a much smaller market but I also happen to think that the Due is not only overkill but that it's design misses the sweet spot by virtue of shoehorning a 32-bit architecture into a 8-bit legacy interface. This 144-pin monstrosity seems to have been selected because one could put out a board in a similar I/O factor configuration as the Mega. But IMO they should have broken from past shield designs for the 32-bit architecture to eliminate the possibility of fried CPUs, enable improved I/O interfacing, among other issues. For me, the 64-pin chip on the teensy offers plenty of I/O out of the box while still being bread-boardable. And the chip is 50% less to buy than the SAM processor on the Due, i.e. about the same price difference as a 328 vs. 1284. And the teensy price vs. Due price reflects that too. I am considering re-designing my DAQ boards around a standard dual pin header for the Teensy. It would eliminate a lot of the complexity from my boards and the CPUs can be re-purposed as needed later. Never mind the on-board RTC, 16-bit ADC (vs. 12 on the Due) etc. But! There is something to be said for the benefits of older 5V-based legacy devices in terms of their ability to drive signals, etc. in ways that the more modern chips cannot.
Dubai, UAE
« Reply #12 on: October 26, 2012, 02:56:40 am » |
Teensy + headers =  I hope to get some time to try some projects out on it this weekend. Duane B rcarduino.blogspot.com
Forum Administrator
I find plain exciting
« Reply #13 on: October 26, 2012, 03:59:28 am » |
Guys... this forum is about the Arduino Due... let's keep in on topic
Lexington, SC
« Reply #14 on: October 26, 2012, 07:48:34 am » |
While not a Mini/Nano, I look forward to an ethernet Due. Phy ethernet and SD card can do some pretty awesome things. I have a Sam3X-EK at work for a project and the demo is pretty slick with a rich web interface but the demo is based on BeRTOS which doesn't have a large community and has custom drivers. Atmel just added "native" lwIP support to asf and will add SD card drivers in the next version(November hopefully) Are the Due drivers ASF-based or from scratch because of licensing issues?
I wonder how the Due firmware would work with the Sam3X-EK, Atmel doesn't even sell the processor(SAM3X8H) on the board.
"Who left the fridge open?" -Tugg Speedman (Scorcher VI - Global Meltdown)
