Topic: Xbee Sereis 1 or Series 2? (Read 2143 times) previous topic - next topic
stefanosfok
Hi All,
I have a general Xbee related question. Which Xbee module is better and for what use, Xbee Sereis 1 or Xbee Series 2?
What are their differences in terms of implementation?
I need to set up an Xbee system with two wireless temperature sensors and looking for my best option between S1 and S2.
Many Thanks!
PaulS
Neither is better. They are for different purposes. The Series 1 models are for point to point use. The Series 2 models are for creating networks of devices.
Depends what you mean by implementation. The XBees needs to be configured (how depends on the series and what it is to do) and need to be connected to the Arduino, usually with a shield, since the XBees use different pin spacing.
Reporting to a central receiver, or talking only to each other?
stefanosfok
Thank you PaulS for your reply,
Currently i have an Arduino UNO with Ethernet Shield and Xbee Shield. I want to receive the temperature from two(or more later on) wireless sensors and display the measured temperature on my laptop through the Ethernet shield.
What do you think is the best option for me, S1 or S2?
PaulS
Currently i have an Arduino UNO with Ethernet Shield and Xbee Shield. I want to receive the temperature from two...wireless sensors
So, you'll have at least three XBees, right? That defines a network, rather than point-to-point, doesn't it? By definition.
stefanosfok
Ok, that is clear. I will go for the S2 then.
Thank you PaulS.
stefanosfok
Dear PaulS,
On the other hand I will have point to point connection from each sensor to the arduino. Do i still need to use the S2?
stefanosfok
I have also found this link which made me really confused.
http://www.digi.com/pdf/chart_xbee_rf_features.pdf
Please, any help will be much appreciated.
Jack Christensen
Two devices are a network, just a minimal one :D
My $0.02 can be read here, FWIW.
If you go with S2 (now called XBee ZB), the low-power wire antenna model is a good one to start with, part number XB24-Z7WIT-004. XB24-Z7PIT-004, XB24-Z7SIT-004, XB24-Z7UIT-004 are equivalent, they just have different antenna options. The Pro models feature increased range and require significantly more power.
