Loading...
Pages: [1]   Go Down
Author Topic: Announce the world first Nano sized Leonardo -Dreamer Nano  (Read 1025 times)
Shanhghai
Offline Offline
Newbie
DFRobot Tech Support
View Profile
WWW
DFRobot just released the first Nano sized Leonardo- Dreamer Nano
The Dreamer Nano V4.0 is a surface mount breadboard embedded version of the ATMEGA 32U4 with integrated Micro USB. It has everything that Leonardo has (electrically).Physically, it is just missing power jack to save space.
Using the ATmega32U4 as its sole microcontroller allows it to be cheaper and simpler. Also, because the 32U4 is handling the USB directly, code libraries are available which allow the board to emulate a computer keyboard, mouse, and more using the USB-HID protocol!
The Dreamer Nano v4.0 is compatible with most Nano shield in the market. It's suitable for projects that require a compact size controller system.
Specification:
  • Input Voltage: 6.5-12v (VIN) / 5v (Micro USB)
  • ATmega32u4 Microcontroller
  • 20 Digital I/O Pins
  • 7 PWM Channels
  • 12 ADCs
  • 16MHz Clock Speed
  • 32 KB Flash Memory
  • Compatible with most of Nano shield
  • Size: 45x20x20mm
« Last Edit: October 25, 2012, 12:57:13 am by dfrobot » Logged
DFRobot-Drive The Future
Official Technical Support for DFRobot Product
www.DFRobot.com
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
It is  not the first small Leonardo - my Leonardino (little leonardo) was out quite a while ago - and I brought out 25 IO lines,
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
God Member
Arduino rocks
View Profile
nice board Robert!..
Im not sure how I missed that?
Is there a thread/discussion on this when/while you were developing it?
thanks!
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Started here
http://arduino.cc/forum/index.php/topic,78631.0.html
Really started to get small around page 6
More here
http://arduino.cc/forum/index.php/topic,88454.0.html
I still have 5 left from the batch of 20 I ordered. I should try putting one together now that I have refllow capability.
Don't think I ever ordered any 32u4 processors.
Logged
Shanhghai
Offline Offline
Newbie
View Profile
WWW
All right. You are the first guy smiley-twist smiley-twist.   Your work looks nice too.
Logged
www.DFRobot.com
Offline Offline
God Member
View Profile
The LeoStick has been around a while too.
http://www.freetronics.com/products/leostick#.UI9i7Wex2Uk
I bought one a while back and quickly ran out of uses for it smiley  - unless there's a way of sending a signal to it, eg (like the guy with V-USB) pressing the caps lock 3 times invokes a function, but I have no idea at all how you apply what the V-USB library does to one of these devices (That includes the Leonardo and clones)
Logged
Pages: [1]   Go Up
Print
Jump to:
