Topic: Digital Protractor (Read 2047 times) previous topic - next topic
evans123
I'm thinking about building a digital protractor (i.e. inclinometer) for my college project and wondered if it would be possible to achieve this without the use of a gyroscope or an accelerometer, therefore using only a tilt switch?
liuzengqiang
Unless you will construct an accelerometer, you will need to buy one. I don't know how a gyroscope comes into the picture. Will your protractor spin? What do you use it for?
If you are willing to put on a force gauge, you can detect angle with that but I don't see why you won't use accelerometer.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Groove
A tilt switch is essentially a digital device, so 'protractor' is not really applicable, unless you've got some controllable tilt table, and you do a binary chop to find the angle of the underlying surface.
Per Arduino ad Astra
evans123
#3
Oct 24, 2012, 06:16 pm Last Edit: Oct 24, 2012, 06:43 pm by evans123 Reason: 1
Ok, thanks. The accelerometer wasn't on the list of sensors that they had available at the university, therefore we would have to purchase one.
What accelerometer's are generally used with the arduino boards? and do you have to purchase any additional components to be able to connect them?
How would the force gauge work?
AWOL
Work out how much of a calibrated load you can measure and do the trig.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
liuzengqiang
Try this:
https://www.sparkfun.com/products/9652
There is nothing else you need. It needs to be powered by the Arduino 3.3V voltage pin. It used to be $30 I think.
evans123
Try this:
Wheres the best place to get one of this from, if you live in the UK?
dxw00d
I don't know about best, but I've used Proto-Pic a few times.
http://proto-pic.co.uk/triple-axis-accelerometer-breakout-mma7361/
evans123
Thanks. Will that breakout board work with the arduino nano?
Far-seeker
It should, the Nano has a 3.3 VDC power pin and eight analog input pins (you need one analog input per axis for that accelerometer IC).
