« on: October 25, 2012, 10:30:04 am » |
I would like to use a 4 digit 7 segment display for a project at university and we have been given an arduino nano. Using the display in the link below would it be possible to connect this to the arduino nano and how many of the pins would it take up? https://www.sparkfun.com/products/11408
Manchester (England England)
Online
Solder is electric glue
« Reply #1 on: October 25, 2012, 10:37:32 am » |
how many of the pins would it take up? 8 (or 7 if you don't want the decimal point) for the segments plus 4 for the common connection so 12 in all. You will also need to multiplex the display to make it look like there is something different on each display.
« Reply #2 on: October 25, 2012, 11:03:34 am » |
Thanks. I take it that they run off digital pins?
I also need to connect an accelerometer to the arduino nano, would I have enough pins left?
Boston area, metrowest
Online
« Reply #3 on: October 25, 2012, 11:16:54 am » |
You have 20 IO pins available. 18 if you reserve D0, D1 for serial interfaciing. Commit 11 or 12 to the display, leaves 6 or 7 free for the accelerometer. Is that an analog outout device> I2C or SPI device? If you need to free up pins, you can use a shift register to write the segments for the display, and gain 4 or 5 back that way (instead of 7/8 segments, have a datapin, clock pin, and latch pin for most shift registers). If you use a 2nd shift register daisy chained with the first, then you can gain the 4 common anode/cathode pins back also.
South England
« Reply #5 on: October 25, 2012, 11:57:29 am » |
The 74HC595 is the standard choice for that sort of application.
« Reply #6 on: October 25, 2012, 12:03:44 pm » |
Thanks. When connecting both the display and shift register to the breadboard / arduino will I need any resistors or other components?
Online
« Reply #7 on: October 25, 2012, 12:11:05 pm » |
Yes, you will need 180 to 220 ohm current limit resistors, 1 for each segment. You will need 100nF caps, one for each shift register's Vcc pin. You will need a ULN2003 to buffer the common cathode signals - each cathode will have up to 160mA flowing thru it if all 8 segments are on. The shift register, or arduino pin, will source current into the anode segments, the ULN2003 will sink current.
« Reply #8 on: October 25, 2012, 12:25:25 pm » |
So thats about 13 resistors then? Is this the buffer I am looking for? http://uk.rs-online.com/web/p/darlington-transistors/4368451/
Online
« Reply #9 on: October 25, 2012, 12:30:39 pm » |
No, just 7 or 8 resistors - they only go in the segment lines, not the common cathode lines. Yes, that's the correct part.
Western New York, USA
« Reply #11 on: October 25, 2012, 02:18:14 pm » |
I would like to use a 4 digit 7 segment display for a project at university and we have been given an arduino nano. ... will I need any resistors or other components? ... Is this the buffer I am looking for? ... Would it be possible to use this buffer instead? What is your major? If it's technology or engineering we don't want to do too much of your work for you.Don
« Reply #12 on: October 25, 2012, 02:24:22 pm » |
I'm a mechanical student and have no idea on electronics.
We're going to be getting some help from an electrician at university, but I'd thought some research wouldn't go a miss first.
« Last Edit: October 25, 2012, 03:11:06 pm by evans123 »
Online
« Reply #13 on: October 26, 2012, 12:35:36 am » |
Would it be possible to use this buffer instead? Yes.
