Author Topic: Grove/Seeedstudio Serial LCD help  (Read 797 times)
(USA)
Hello,
I bought a Grove starter bundle about a year ago. I got busy working on some of my robots (not Arduino)  and have not gotten to use the LCD yet. I can not figure out how to get the LCD display to work. I have little experience with the Arduino. The wiki seems extremely outdated and I need some help.   Link to wiki…. (I have the middle LCD display)
http://www.seeedstudio.com/wiki/Grove_-_Serial_LCD
Here is what I need help on…
1. What library do I need?
2. Could somebody provide me with a basic sketch? Perhaps one that makes it say "hello world".
Any help would be appreciated ,
Drew R. Davis
« Last Edit: October 25, 2012, 04:24:42 pm by drewdavis » Logged
Saskatchewan
When the going gets weird, the weird turn pro. - Hunter S. Thompson
I had no problems using the one linked to on that page under the important note. They call it the unified library.
IIRC it has some good samples.
(USA)
What is IIRC?
Thanks,
Drew R. Davis
(USA)
Also, when I try to verify the "HelloWorld" program this is what I get …
HelloWorld.pde:-1: error: 'SerialLCD' does not name a type
HelloWorld.cpp: In function 'void setup()':
HelloWorld.pde:-1: error: 'slcd' was not declared in this scope
HelloWorld.cpp: In function 'void loop()':
Does it matter that I use a mac?
Thanks,
Drew Davis
Manchester (England England)
Solder is electric glue
No.
Looks like your libaries are not installed or are not compatable with the version of IDE you are running.
Saskatchewan
IIRC - if I recall correctly
It's probably not installed correctly.
(USA)
First off, thank you helping me.
Now onto how I installed it…
1. I downloaded the zip file "SerialLCD"
2. My Mac auto unzipped "SerialLCD"
3. I dragged the unzipped folder "SerialLCD" (with all of it's contents) to "libraries" in my "arudino-1.0.1 folder"
4. I closed the folder
5. I started the Arduino programing (should be the newest version)
6. Then I went  to "open program"  and navigated into "libraries" went into the "SerialLCD"  subfolder and opened up the example "hello world"
7. I tried to verify and got the error codes I listed
Could you please tell me where I went wrong.
Thanks,
Drew R. Davis
« Last Edit: October 25, 2012, 08:03:57 pm by drewdavis » Logged
(USA)
I have the newest version of the library, and I have the newest version of the Arduino programing software.
What can I do?
I would really like to use my LCD screen.
Thanks,
Drew Davis
Western New York, USA
But the library you are using was not provided with the Arduino programming software (IDE) and although it is the 'newest' it probably isn't new enough.
What can I do?
You could start by searching for the phrase you are getting in your error message such as "was not declared in this scope" or "does not name a type".  Note that I left out the part that contains the name of the library in order to widen the search.
Don
(USA)
I have searched everywhere and did not find anything. Posting on this forum was my last resort.
Could I use a library for a different LCD display?
Dallas, TX USA
The errors you have show so far indicative of the library not being installed.
My guess is that the library still isn't correctly installed.
(The SerialLCD HelloWorld sketch builds just fine for me using Arduino 1.0.1)
Try getting to the example this way:
[File]->Examples->SerialLCD->HelloWorld
If you don't see "SerialLCD" showing up in the list of examples,
the SerialLCD library is not properly installed.
--- bill
(USA)
Your right it was not installed correctly. I had it in a different Arduino folder.
Thanks for the test to see if a library is installed correctly!!!
Also, thanks to all the people who helped me resolve the issue!!!
Thanks again,
Drew Davis
