Topic: support serial communication and TFT display (Read 1 time) previous topic - next topic
Maxloom
Hello!!
I recently purchased a TFT 3.2 "", works perfectly, but when I want to add my serial communication program, it stops working, anyone can help me???
:smiley-eek: :smiley-eek: :smiley-eek: :smiley-eek:
PaulS
Quote
What program would that be?
Maxloom
this is a program code for example:
#include <Wire.h>
#include <ITDB02_Graph16.h>
extern uint8_t SmallFont[];
ITDB02 myGLCD(A1,A2,A0,A4,A5,2);   //
   myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  int buf[238];
  int x, x2;
  int y, y2;
  int r;
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 306, 239, 319);
  myGLCD.setColor(255, 255, 255);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("prove", CENTER, 1);
  Serial.print("TEST PC");
  When I open the hyper terminal screen turns off. I need not turn off and I want to communicate with a PC to modify or query data during program execution.
PaulS
Quote
that won't even compile. Try again.
Maxloom
Code: [Select]
#include <Wire.h>
   myGLCD.InitLCD();
  int buf[238];
  int x, x2;
  int y, y2;
  int r;
  myGLCD.clrScr();
the libraries are given by the manufacturer default.
Code: [Select]
//ITDB02_Graph16.h
#ifndef ITDB02_Graph16_h
#define ITDB02_Graph16_h
#define LEFT 0
#define RIGHT 9999
#define CENTER 9998
#define PORTRAIT 0
#define LANDSCAPE 1
#define ASPECT_4x3 0 // Legacy
#define ASPECT_16x9 1 // Legacy
#define ITDB32 0 // HX8347-A
#define ITDB32WC 1 // ILI9327
#define TFT01_32W 1 // ILI9327
#define ITDB32S 2 // SSD1289
#define TFT01_32 2 // SSD1289
#define TFT01_24 3 // ILI9325D
#include "Arduino.h"
struct _current_font
uint8_t* font;
uint8_t x_size;
uint8_t y_size;
uint8_t offset;
uint8_t numchars;
class ITDB02
public:
ITDB02();
ITDB02(int RS, int WR,int CS, int RST, int ALE, byte model=ITDB32);
void InitLCD(byte orientation=PORTRAIT);
void clrScr();
void drawPixel(int x, int y);
void drawLine(int x1, int y1, int x2, int y2);
void fillScr(byte r, byte g, byte b);
void drawRect(int x1, int y1, int x2, int y2);
void drawRoundRect(int x1, int y1, int x2, int y2);
void fillRect(int x1, int y1, int x2, int y2);
void fillRoundRect(int x1, int y1, int x2, int y2);
void drawCircle(int x, int y, int radius);
void fillCircle(int x, int y, int radius);
void setColor(byte r, byte g, byte b);
void setBackColor(byte r, byte g, byte b);
void print(char *st, int x, int y, int deg=0);
void printNumI(long num, int x, int y);
void printNumF(double num, byte dec, int x, int y);
void setFont(uint8_t* font);
void drawBitmap(int x, int y, int sx, int sy, unsigned int* data, int scale=1);
void drawBitmap(int x, int y, int sx, int sy, unsigned int* data, int deg, int rox, int roy);
void LCD_Writ_Bus(char VH,char VL);
void LCD_Write_DATA(char VH,char VL);
protected:
byte fcolorr,fcolorg,fcolorb;
byte bcolorr,bcolorg,bcolorb;
byte orient;
long disp_y_size;
byte display_model;
volatile uint8_t *P_RS, *P_WR, *P_CS, *P_RST, *P_ALE;
uint8_t B_RS, B_WR, B_CS, B_RST, B_ALE;
_current_font cfont;
void LCD_Write_COM(char VL);
void main_W_com_data(char com1,int dat1);
void setPixel(byte r,byte g,byte b);
void drawHLine(int x, int y, int l);
void drawVLine(int x, int y, int l);
void printChar(byte c, int x, int y);
void setXY(word x1, word y1, word x2, word y2);
void rotateChar(byte c, int x, int y, int pos, int deg);
#endif
PaulS
Code: [Select]
  int buf[238];
What's this huge array for? That's using 1/4 of the memory on a 328-based Arduino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
