Topic: Regression between uno and uno R2 VALIDATED. HARDWARE PROBLEM CONFIRMED (Read 42626 times) previous topic - next topic
pico
So just out of interest, what was the "official" fix in the R3 Uno? (I know, I could just dig up and compare schematics, but I'm lazy -- sorry.)
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
CrossRoads
john1993
So, do like this?
yes, i now realize thats the best solution. if shield is needed the diode can be installed on it or on the bottom of the uno. thanks for the photo, its just what i needed for those who cant read schematics or dont solder..
btw i did try leaving out the cap on some of my minimal bbb type boards. it worked in most cases but failed with some serial usb dongles. sometimes due to timing issues and other failures caused by polarity. with cap and diode it works all the time so now i mount both on the dongle. this way even a bare chip (literally zero external components) can be programmed via the ide or avrdude alone.
pico
CrossRoads
Cathode to +5. Anode to reset pin.
Any spikes on the reset pin are shunted to the +5V supply.
I use 1N4158.
pico
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
