Topic: 2000 volts through an LED, no resistor. (Read 3019 times) previous topic - next topic
nickgammon
This fellow puts 2000 volts through an LED. It doesn't last long.
http://www.youtube.com/watch?v=8hwLHdBTQ7s
Boffin1
They dont make resistors like they used to  :-)
couldnt he find an 82k  50 watt resistor in the drawer ?
45 years of editing projects with a knife and soldering iron, then I found Arduino !
GoForSmoke
Isn't it tantalum caps that go bang hooked in reverse?
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
Boffin1
I thonk you must have missed out on some fun in your youth GoForSmoke :-)
   Normal electrolytics used to make a great explosion, even now with the precut cross on the top they can still explode or make a hissing smoke stream as the can ruptures at the top.
GoForSmoke
In my youth it was KClO3, S and Al powder and once I had a kilo of Na metal. Later on I learned how much safer KClO4 and Al are. I don't compare exploding capacitors to any of those.
Boffin1
When I was about 14, I was in the garage switching on a power supply I had just built for the old "19 set" tank wireless from army surplus store.
I had the headphones on, and there was a delay as the rectifier valve warmed up and put 300 volts on the main electrolytic capacitor ( that I had wired reversed )
The hum started building in my ears, and my Dad proudly walked into the garage with his mate to show off what a boffin his son was.
The bang was deafening,  the can of the cap shot down the garage, followed by a spiral of smoking aluminium foil.
I don't think Dad ever mentioned my hobby to his mates after that.
Boffin1
" Later on I learned how much safer KClO4 and Al are"
I am useless at chemistry,  is that the mix that catches light when a drop of water gets on it ?
I know it was crystalized something or other  with aluminium filings.
Osgeld
tants will also explode and burn if abused
Ran Talbott
The guy had two hundred and forty-bleeping-four used 9V batteries on hand?!!?!!?
The LEDs were actually a rather anti-climactic yawn. What was really amazing about that video is that he had enough uncluttered space to plug all those batteries together and lay them out flat.
nickgammon
Now if he'd put his tongue on it, that would have been interesting.
Like those Darwin awards.
