Topic: Determine valve handle position (Read 752 times) previous topic - next topic
tjjunior
Hi all,
Any suggestions on the best way to determine the position of a ball valve?  I'd like to use the existing valve which is similar to:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=441744
Can I mount something on the handle that would still allow it to be used in the normal fashion?  I could live with a binary response (fully closed vs not fully closed), preferred would be 3 levels:  Fully closed, fully open, somewhere in between.  The valve would still be operated by hand, I just need to know the status of the valve elsewhere (e.g. if the engine is operating while this valve is closed, give a warning signal to the operator).
Suggestions on an inexpensive sensor I could use to send a signal to the Arduino?
Thanks!
johnwasser
You could use a potentiometer on a bracket that mounts it over the valve axis.  The Arduino could then measure the valve position.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
PeterH
A microswitch that is closed when the valve is closed, in series with a switch that is closed when the engine is running, powering a lamp, seems to be all you need. How to arrange the 'engine running' switch is a question only you can answer, but it does not seem likely to be difficult.
tjjunior
I think the micro switch is exactly the route I was trying to think of.  I'll give both a shot and see how it goes from there, thanks! The engine test should be pretty basic, not too worried about that one.
