Topic: 3Byte Two's Compliment (Read 1 time) previous topic - next topic
wally123
Hello,
is there a smart way to handle signed 24 bit integers ?
(without using "if" etc.)
Seems gcc > 4.7 supports a uint24_t nad int24_t datatype.
My ADC returns 3 Bytes conversion result as int24_t.
wally
dhenry
"Smart" is highly subjective.
A "simple" way is to hand it to a signed long.
wally123
dhenry,
agree :)
  Serial.println("signed 24bit test\n");
  int32_t value[]={0x800000, 0xFFFFFF, 0x0, 0x000001, 0x7FFFFF};
// exp result     -8.388.608,    -1   ,  0 ,    +1   , 8.388.607
  for(int i=0; i<5; i++) {
    Serial.print(value[i], HEX);
    Serial.print("\t");
    Serial.println(value[i], DEC);
  Serial.print("___________________");
output:
  signed 24bit test
  800000   8388608         // expected -8.388.608
  FFFFFF   16777215        // expected  -1
  0           0
  1           1
  7FFFFF   8388607
   _________________
i', playing around with bit manipulation (shift, toggle, etc.) but
it always end up in requirement to use an IF condition.
"smart" would be without 'IF' but a straight conversion line ( or 2)
wally
AWOL
You'd need to do the sign extension yourself, or get the compiler to do it for you, by starting with 32 bit signed vales and truncating to 24.
e.g.
int32_t value[]={0xFF800000, 0xFFFFFFFF, 0x0, 0x000001, 0x7FFFFF};
dhenry
What about this:
1) left align the 3 bytes to an unsigned long type. Making sure the last byte is 0.
2) Point a signed long pointer to the unsigned type.
3) right shift the unsigned type.
dhenry
How about this:
a signed long type = ((signed long) (value << 8)) >> 8;
Essentially the approach I outlined earlier. It creates a left aligned unsigned long type (32-bit). Then it cast it to signed long to preserve the signage. After that, you right shift it to return the right value.
See if it works.
wally123
dhenry,
this is exactly what i meant by "smart"  :)
Thank you very much
wally
