Topic: Boot loading 168A-PU (Read 737 times) previous topic - next topic
ars
Is ATMega 168A-PU compatible (physically) for boot loading arduino? If so, I always get an invalid device signature error when trying to bootload it from within the arduino IDE? How to successfully bootload it?
Nick Gammon
What board are you selecting?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Henrik67
Well, if you supply the correct device signature it should work...
ars
I am selecting the arduino NG or older board and is this IC physically compatible to handle arduino or am I just wasting my time?
Nick Gammon
Quote
Yes, of course, or the Atmega168 wouldn't be on the list. Perhaps if you describe in more detail. Your first post told us practically nothing. What programmer device are you using? What board are you using? Did you make it yourself? What is the wiring? Are you using a crystal? Photo please.
More info:
westfw
The ATmega168A has the same signature as the ATmega168, so it should work fine.
Turn on verbose mode to see what signature you are actually getting.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
