Loading...
Pages: [1]   Go Down
Author Topic: mettere in pausa arduino finchè non riceve un dato da seriale  (Read 195 times)
Offline Offline
Jr. Member
View Profile
ciao a tutti,
questo è il codice che ho di riferimento
Code:
#define RELAY_PIN 3 //digital pin to control the relay
#define c_pin A1    //capacitor analog pin
#define ps_pin A0   //power supply analog pin
// defines for setting and clearing register bits
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
  // set prescale to 16
  sbi(ADCSRA,ADPS2) ;
  cbi(ADCSRA,ADPS1) ;
  cbi(ADCSRA,ADPS0) ;
  pinMode(RELAY_PIN, OUTPUT);
  Serial.begin(9600); // open serial
  Serial.println("Press the spacebar to toggle relay on/off");
  static int relayVal = 0;
  int cmd;
  float c_voltage, ps_voltage, current;
  static float res = 4.464;
  unsigned long time1, time2, time_0;
  while (Serial.available() > 0)
    cmd = Serial.read();
    switch (cmd)
    case ' ':
        relayVal ^= 1; // xor current value with 1 (causes value to toggle)
        if (relayVal)
          Serial.println("Relay on");
    default:
    if (relayVal)
      digitalWrite(RELAY_PIN, HIGH);
      delay(20);            // relay transition time
      time_0 = micros();    // time the measure start
      do
        c_voltage = analogRead(c_pin);
        time1 = micros()-time_0; //time c_voltage measurement
        ps_voltage = analogRead(ps_pin);
        time2 = micros() - time_0; //time ps_voltage measurement
        c_voltage = c_voltage *5 /1023;
        ps_voltage = ps_voltage * 5 / 1023;
        current = (ps_voltage - c_voltage)/res;
        Serial.println(ps_voltage);
        Serial.println(time1);
        Serial.println(c_voltage);
        Serial.println(time2);
        Serial.println(current);
        Serial.print('\n');
      while(current >0.000001);
      Serial.println("Please wait for the capacitor to discharge");
      digitalWrite(RELAY_PIN, LOW);
      do
        c_voltage = analogRead(A1);
        c_voltage = c_voltage * 5 / 1023;
        delay(50);  // just a delay to not print all the values
      while(c_voltage > 0.001);
      relayVal = 0;  // reinitialze the relayVal
      Serial.println("\nThe relay is off, press the spacebar");
      Serial.println("again if you want to repeat the measure\n");
questo codice mi permette di acquisire la misura ogni volta che premo la spacebar
ho provato a modificarlo chiedendo direttamente il numero di misure che si vogliono effettuare ma non capisco perchè, appena carico il codice, tutto va in automatico senza aspettare che io inserisca il numero. dove sbaglio???
Code:
#ifndef cbi
#endif
#ifndef sbi
#endif
  sbi(ADCSRA,ADPS2) ;
  cbi(ADCSRA,ADPS1) ;
  cbi(ADCSRA,ADPS0) ;
  Serial.println("How many measure do you want to take?");
  int num_misure;
  static float res = 3.59;
  unsigned long time1, time2, time0;
  int i ;
  if(Serial.available() > 0)
        num_misure = Serial.read();
   num_misure = int( num_misure);
    for(i=1; i<=num_misure;i++)
      Serial.print("Misura n.");
      Serial.println(i);
      delay(20);            // relay transition time::::::: problema, ho impostato questo ritardo per aspettare la commutazione del ralay, ma questo non ha un tempo fisso
      time0 = micros();    // time the measure start
      do
        time1 = micros()-time0; //time c_voltage measurement
        time2 = micros() - time0; //time ps_voltage measurement
        Serial.print('\n');
      do
      Serial.print("\n\n");
« Last Edit: October 26, 2012, 09:52:55 am by aureliusss » Logged
Forum Moderator
Italy
Offline Offline
Brattain Member
Don't know what I do
View Profile
Il primo if legge un valore dalla seriale ma poi il codice continua anche se tale valore non è stato ricevuto.
Ci sono tanti modi, uno è quello di mettere un secondo if e far eseguire la lettura solo se il valore di num_misure è maggiore di 0, ad esempio.
Code:
if (Serial.available() > 0) {
    if (num_misure > 0) {
Logged
Offline Offline
Jr. Member
View Profile
grazie mille, ma esiste proprio un modo per far stoppare l'esecuzione finchè non si riceve un valore?
vorrei capire perchè il codice di riferimento si ferma mentre il secondo continua
Logged
Cagliari
Offline Offline
Faraday Member
View Profile
Si. Puoi bloccare l'esecuzione con un while. Come scritto nel primo codice.
Code:
while (Serial.available() > 0);
Finché non si riceve un carattere dalla seriale il codice rimane bloccato nel ciclo while
Logged
IDE 1.0.4 - Arduino UNO R3 - Ethernet Shield R3 - DCF77 Module - Adafruit Data Loggin Shield - LCD 16x2 RGB positive backlight - i2c LCD backpack - RTC 1307 Board - Saleae Compatibile Logic Analyzer 8ch 24Mhz - ATtiny2313 ProtoBoard - Xino Board - ATtiny 4313 - Arduino 2009 - Arduino USB Serial Ligth - DS18B20 - LM35DZ - ShiftRegister - TL431 - ATtiny 85
Ultimi acquisti:
CodeBender: http://codebender.cc/register/?referrer=PaoloP
Offline Offline
Jr. Member
View Profile
damn, altro problema, se inserisco un numero con più cifre me le legge una alla volta
Logged
Cagliari
Offline Offline
Faraday Member
View Profile
Quote
This not a bug, this is a features!
La seriale legge un carattere alla volta.
Per ricomporlo devi crearti un buffer e caricare su di esso i caratteri letti.
Sul forum trovi 1000 esempi di codice per questo problema.
Logged
Ultimi acquisti:
Pages: [1]   Go Up
Print
Jump to:
