Topic: Help with Winstar WG12232A-TMI-N#A (Read 1 time) previous topic - next topic
jokkis
Hei Guys!
I'm pretty new to this. I've just bought an ArduinoMega, and a LCD display to get starting with.
After a week with long evenings i still can't get it to work.
I have tryed everyting(in my opinion). I want to solv this my self tho, but need a little hint. can someone please give me a hint what I'm doing wrong and point me in the right direction?
datasheet: http://www.rapidonline.com/pdf/57-2272.pdf
LCD - ArduinoPIN
gnd - gnd
Vdd - +5V
Vo - contrast adjusting(working)
A0 - 46
CE1 - 47
CE2 - 48
R/W - 49
RES - 2
DB0->DB7 - 30->37
LCDbacklight working.
I have tried with the liquidcrystal lib with no success.
I have also tried some coding my self without luck.
the only thing that happens is that i get a white line at the bottom og the display, and the whole screen fades white.
here is my code:
  //RESTART PIN
    pinMode(2, OUTPUT);
    digitalWrite(2, LOW);
    delay(20);
    digitalWrite(2, HIGH);
    myLCDtest();
void myLCDtest() {
  PORTC = B00000000;
  DDRC = B11111111;
  PORTL = B00000000;
  DDRL = B00001111;
  PORTL = B00000101;
  PORTC = B11000011;
  delay(2);
  PORTL = B00000001;
  PORTC = B00000000;
floresta
I believe that your device is a graphical lcd (GLCD) as opposed to being a character mode lcd, therefore the LiquidCrystal library is not appropriate.
According to the data sheet the controller chip is a SBN1661G_M18-D or equivalent.
Now you have to determine if it is equivalent to the KS0108 or the ST7920 for which there are libraries available.
 KS0108 library:  http://www.arduino.cc/playground/Code/GLCDks0108
 ST7920 library:  http://code.google.com/p/u8glib/
Hopefully bperrybap will spot this and chime in with better information.
Don
olikraus
Hi
U8glib should support the SBN1661 controller (it differs from KS0108 and ST7920). The constructor is:
U8GLIB_SBN1661_122X32 u8g(d0, d1, d2, d3, d4, d5, d6, d7, cs1, cs2, di, rw );
In your case (with A0 = DI):
U8GLIB_SBN1661_122X32 u8g(30, 31, 32, 33, 34, 35, 36, 37, 47, 48, 46, 49);
Oliver
jokkis
