Topic: MIDI OUT as CC Messages (Read 929 times) previous topic - next topic
abidethedude
Hi guys
Right now I am working on using an arduino as a simple MIDI controller.
I was able to get the arduino to send out MIDI note number easily to a DAW (I am using Reaper). So i figured sending out CC messages would be simple
However I am not getting any respond from the DAW when assigning MIDI data. Could it be the way it is sending?
Here's an example of what I've written:
Code: [Select]
ProcessMIDIOut(176,14,76);
where 176= Channel 1 Mode, 14: unsigned , 76: value
The function is as so:
Quote
void ProcessMIDIOut(byte cmdtype, byte val1, byte val2)
 //bugging test purposes: to see what values the TX pin is sending out.
  SSerial.print("?x00?y2");
  if (cmdtype == PITCHBEND)
    Serial.write(0xE0 | (channel & 0xf));            //  control change command ***Error here:: "As of Arduino 1.0 the "BYTE" keyword is no longer supported. Please use Serial.write () instead
    Serial.write(val1 & 0x7f);                       //  pb MSB 0-127
    Serial.write(val2);                              //  pb LSB 0-15 - TODO
  else // All standard note and cc messages
    Serial.write(cmdtype | (output_channel & 0xf));  //  control change command
    Serial.write(val1);                           //  command
    Serial.write(val2 & 0x7f);                       //  val1 0-127
and yes, Serial is in the right MIDI baud.
I'm still new to the CC messages format
dxw00d
Does Reaper know what to do with a control number of 14? It's listed as undefined in the messages spec.
Nantonos
Where in your code do you set the values of output_channel and channel?
