Topic: ardunio to read and send info to pc via wifi shield for wind turbine (Read 1 time) previous topic - next topic
michaelalbert
looking for any ideas in how to get this project off the ground, programming is the main issue  if any one can give me some ideas i'd appreciate it   The info need to send will be the voltage, current, and RPM's  looking for a basic example  with which I can build on    thanks  michael
robtillaart
on the playground you will find most examples you need - temp - http://www.arduino.cc/playground/ComponentLib/Thermistor2
voltage and current - https://www.sparkfun.com/products/9028
what precision do you need?
what frequency of measurements?
do the sensors need to be in the turbine? OK the rpm does, check this   - http://arduino.cc/forum/index.php/topic,128147.0.html -
Rob Tillaart
michaelalbert
#2
Oct 27, 2012, 10:20 am Last Edit: Oct 27, 2012, 10:27 am by michaelalbert Reason: 1
basically attaching arduino to wind turbine to monitor output and then having the arduino send the info wirelessly to the PC. Using a small turbine to power the blades while the arduino monitors the charging output and send to the PC over the Wifi. Any ideas on how to get this to work programming wise.  Voltage output between 5 volts and 9 volts stops charging if over 9v and starts if under 5v. trying to have wind turbine charge battery and monitoring charge rate. Frequency roughly 60Hz
thanks again  michael
robtillaart
The links I posted contains  sample sketches.  Have you tried to read and understand them?
Rob Tillaart
michaelalbert
thank you will review them in depth if I have in more questions I will ask you again thanks
