Topic: Arduino UNO as ISP using ICSP -> ATtiny 85 ? (Read 2126 times) previous topic - next topic
rheine
I want to know if I can use the ICSP header to connect to my attiny85 dev board that has a 5X2 ICSP to program it.
Or is this not what it is for? Is there a guide for this?
http://www.sparkfun.com/products/33
fungus
No.
Most of the pins on the ICSP header would be OK but one of them is RESET and you can't control that in software.
It's an input, not an output.
You can use it to program the Arduino directly instead of using the serial port. You can use it to burn new serial bootloaders, etc., or even bypass the bootloader altogether.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
rheine
Oh, OK, clears that up. Can I use a serial cable from my computer to the serial on the dev board to program it then?
fungus
Yes... if it has a bootloader burned on it and you press reset just before you start sending.
Special Arduino serial cables ("FTDI") have the reset thing built-in.
