Author Topic: Voltage step up alternatives  (Read 658 times)
Sweden
Hi!
I need to build a boost converter (step up to 30-40V 100mA 20mA to drive a IV-18 VFD) and have found three alternatives.
Alt 1.  555 IC, Inductor, Diode and capacitor (http://www.benjscott.com/2009/07/555-boost-converter/)
I tried alt 1 this week and it worked fine. By modify the frequency on the 555 I could change step up voltage easy.
First try I got 120V from 5V smiley
Alt2. MC34063
Bought 10 pieces of MC34063 from ebay. Never used them but should be able to work as a step up converter to 40V.
Alt3. Voltage tripler circuit (http://www.electronics-tutorials.ws/blog/voltage-multiplier-circuit.html)
If I could find a 12v AC/AC adapter, I could triple the voltage to 36V DC.
What is the pros/cons with the three alternatives?
/Olof
« Last Edit: October 27, 2012, 10:43:54 am by olof_n » Logged
1: cheap and stable;
2: cheap. but not as efficient;
3: not workable for your purpose.
You can also configure your arduino into a boost controller.
Sweden
Thanks for the quick reply!
That is good because alt 1 was very easy to build.
/Olof
Austin, TX
CMiYC
I'm not familiar with the current requirements of the VFD, but the 555 solution is only ideal if the load never varies.  The MC34063 is a regulator and will provide a stable output as load as the load is within its specs.
www.cmiyc.com - A guide to being an Enginerd
Germany
By simulating a 555 (oscillator with variable frequency) ?
If there's more about it, can you please tell a bit more?
Controller means regulating, right? Is the Arduino ADC fast enough to work in a closed loop in that area?
Depends on how you have implemented it. For example, applying the feedback to Pin 5 will help hold the voltage steady under varying load.
South England
I tried the 555-based step up circuit last night, just to see how I got on with it using the parts I had on-hand... it worked surprisingly well! For the 555 stage I used:
R1 & R2 = 100ohms
C = 0.22uF
And for everything else:
Diode = UF4007
MOSFET = 2SK2718 (pulled from an old dot matrix printer)
L = 470uH
Setting my bench supply to 7.2V I was getting well over 700V on the output with a current draw of around 100mA, and it charged a small bank of photoflash caps very quickly smiley-grin Think I might build a permanent version, it's got to be useful for something!
« Last Edit: October 28, 2012, 10:09:56 am by BulletMagnet83 » Logged
Some people will use the 555-based boost converter for tube amplifiers so yes, it can work.
However, 7.2v -> 700v means 10% duty cycle and that may be pushing closer to the chip's limit - I think they are like 5% to 95%. Check your datasheet to be sure.
South England
I just checked on a 555 calculator, and according to that it's 66.6% duty cycle and 21.8KHz. Oh well, it was fun to play with anyway... with a few tweaks I might be able to make something useful out of it. I quite fancy playing with an IV-18 (or similar) myself, they're cool looking tubes!
Sweden
700V smiley - maybe you could build a fly killer racket.
