Topic: Audio out and speaker (Read 2357 times) previous topic - next topic
Pancra85
I am working on some sort of synth and want to add a speaker output but also a line out, and if I am using line out the speaker should be deactivated.
I was thinking that I can use this amplifier: http://makezine.com/images/09/CrackerboxAmp_Schem.pdf and have a switch on the OUT after the Master volume so it can switch between speaker and line out
Will that work ok? with no noise or problem at all?
Thanks!
fungus
#1
Oct 27, 2012, 10:47 pm Last Edit: Oct 27, 2012, 10:49 pm by fungus Reason: 1
Thanks!
You can get jack sockets with built-in switches for doing this sort of thing. Connect your speaker through the socket and when you plug something into the socket it gets disconnected.
Lakes
Pancra85
Oh... so when I connect the line out the speaker gets automatically disconnected? That is awesome.
And R9 is the volume, right?
Thanks!!
Lakes
Yes, R9 is the volume control, but you still need a switching jack socket (or some other means) to disable the speaker.
Pancra85
ok, and where the switch of the audio jack goes connected on that schematic? If it were a normal switch I would think that the switch goes from R7 to speaker, but I have no idea how to do it with a built in switch as it has only one connector.
also, I dont see R7 value and what value should be correct for the R9 potentiometer?
Lakes
dhenry
Find a jack that will disconnect the amplifier when you insert your line-out phone.
Pretty common.
Pancra85
ok, yes, but where do I connect the switch output of the jack?
fungus
You're OK with the the schematic above but can't wire up a mechanical switch...?   :~
Lakes
To keep things simple just wire a slide or toggle switch in series with the speaker.
One phono socket for input, one jack socket for line out, (you can`t get them mixed up that way).
fungus
http://www.ebay.com/sch/i.html?_nkw=jack+socket+switch+3.5mm
Pancra85
Hey, thank you very much to all for the great help and the time!
I think I got it now, the jack will act as a jumper when a plug is connected, that goes in series to the speaker.
I'll buy some from ebay!
