Topic: Direct Port Manipulation Through a variable - help (Read 2166 times) previous topic - next topic
DuaneB
    I am trying to access a port through a variable as in -
thePort = PORTB;
thePort ^= 255;
    Whatever I do I cannot get this to work inside a library - I am sure its something daft but I need another pair of eyes to see it
Thanks
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Coding Badly
#1
Oct 28, 2012, 08:55 am Last Edit: Oct 28, 2012, 08:59 am by Coding Badly Reason: 1
Try this...
static uint8_t volatile * thePort;
thePort = & PORTB;
*thePort ^= 255;
Edit: Forgot the ampersand.
robtillaart
your code makes a copy of the value in the port, you should write it back.
thePort = PORTB;
thePort ^= 255;
PORTB = thePort;
Rob Tillaart
DuaneB
   Thanks all, mystery solved, it was the forgotten ampersand.
Thanks
Duane B.
Read this
then watch this
dhenry
DuaneB
Read this
then watch this
WizenedEE
volatile uint8_t& thePort = PORTB;
thePort ^= 0x08
