Topic: Calculating csv file size (Read 4594 times) previous topic - next topic
hdmafukidze
I am logging sensor data to a scv file. I need to calculate the size of this csv file before sending it over to the serial port.
any one with experience on this......
robtillaart
Can you be more specific?
What OS?
What is in the CSV?
How many fields?
What datatype is every field?
How do you want to send the data?
- binary/ascii
- uncompressed/compressed
- otherwise
The more you tell about the problem the better help you get
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
PaulS
Where is the csv file stored? If the csv file is on an SD card, the SD library has a way to determine the size of a file.
PaulS
Quote
i would like to send data to a satellite modem in binary format. So to successfully send the message, the modem has to know the  length, in bytes, of the message the arduino is sending.
Are you planning to send the whole file in one package? That will require reading the whole file, and storing it in SRAM, of which you have only 2048 bytes (and the SD library needs 512+ of them). If so, simply count the characters as you read them from the file (you'll need to do that to store them in the correct place in the array, anyway).
If not, and this is the more likely scenario, then the size of the csv file is irrelevant. It is the size of the package that you need to know. And, that depends on how you want to package data to be sent. Maybe, one record at a time. Of course, this requires that you know what a record looks like (i.e. when it ends).
bubulindo
End address - Start Address = size
Sorry for being so short, but it's not like you provided a lot of info...
This... is a hobby.
AWOL
Quote
sp. "(End address - Start Address) + 1 = size"   ;)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Nick Gammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
