Offline
Newbie
« on: October 28, 2012, 02:48:32 pm » |
hola este ejemplo sale en el web del producto i lo kiero connectar con un arduino mega con el sholud atmega connecta i listo pero no ve en el programa la entrada que utiliza alguien puede auyudarme? no veo donde se configura i indica las entradas que usa
#include "Wire.h" #define DS1307_I2C_ADDRESS 0x68 // This is the I2C address // Global Variables int command = 0; // This is the command char, in ascii form, sent from the serial port int i; long previousMillis = 0; // will store last time Temp was updated byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; byte test; // Convert normal decimal numbers to binary coded decimal byte decToBcd(byte val) { return ( (val/10*16) + (val%10) ); } // Convert binary coded decimal to normal decimal numbers byte bcdToDec(byte val) { return ( (val/16*10) + (val%16) ); } // 1) Sets the date and time on the ds1307 // 2) Starts the clock // 3) Sets hour mode to 24 hour clock // Assumes you're passing in valid numbers, Probably need to put in checks for valid numbers. void setDateDs1307() { second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result. minute = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48)); hour = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48)); dayOfWeek = (byte) (Serial.read() - 48); dayOfMonth = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48)); month = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48)); year= (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48)); Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0x00); Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock Wire.write(decToBcd(minute)); Wire.write(decToBcd(hour)); // If you want 12 hour am/pm you need to set // bit 6 (also need to change readDateDs1307) Wire.write(decToBcd(dayOfWeek)); Wire.write(decToBcd(dayOfMonth)); Wire.write(decToBcd(month)); Wire.write(decToBcd(year)); Wire.endTransmission(); } // Gets the date and time from the ds1307 and prints result void getDateDs1307() { // Reset the register pointer Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0x00); Wire.endTransmission(); Wire.requestFrom(DS1307_I2C_ADDRESS, 7); // A few of these need masks because certain bits are control bits second = bcdToDec(Wire.read() & 0x7f); minute = bcdToDec(Wire.read()); hour = bcdToDec(Wire.read() & 0x3f); // Need to change this if 12 hour am/pm dayOfWeek = bcdToDec(Wire.read()); dayOfMonth = bcdToDec(Wire.read()); month = bcdToDec(Wire.read()); year = bcdToDec(Wire.read()); Serial.print(hour, DEC); Serial.print(":"); Serial.print(minute, DEC); Serial.print(":"); Serial.print(second, DEC); Serial.print(" "); Serial.print(month, DEC); Serial.print("/"); Serial.print(dayOfMonth, DEC); Serial.print("/"); Serial.print(year, DEC); Serial.print(" "); } void setup() { Wire.begin(); Serial.begin(57600); } void loop() { delay(2000); /*T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99) - T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year) - T Sets the date of the RTC DS1307 Chip. Example to set the time for 02-DEC-10 @ 19:57:11 for the 3 day of the week, write this command - T1157193021210 */ if (Serial.available()) { // Look for char in serial que and process if found command = Serial.read(); if (command == 84) { //If command = "T" Set Date setDateDs1307(); getDateDs1307(); Serial.println(" "); } while(1) { getDateDs1307(); delay(500); } } }
