Loading...
Pages: [1] 2   Go Down
Author Topic: MOFET selection to run 12v  (Read 729 times)
Offline Offline
Newbie
View Profile
I am trying to control some LED strip lights (12V, 2 AMP) with the arduino and am trying to select the correct MOSFET to handle the load. I thought this one (http://www.vishay.com/docs/91325/sihlz14.pdf) might work but it does not. When connected with all the pull down and limiting resistors, the lights are dim. Then I noticed when I connected the Drain to Source without the gate power was getting through and dimly lighting the lights...I have researched several sites and similar projects but they do not have the same conditions.
 Any thoughts? Thanks community!
Logged
Offline Offline
Newbie
View Profile
MOSFET - is what I meant to type..
Logged
Valencia, Spain
Online Online
Edison Member
View Profile
It helps if you tell us how you connected it up.
Logged
Offline Offline
Newbie
View Profile
Here is the link to the schematic:
http://img19.imageshack.us/img19/8075/12vschematic.jpg
Thanks for the help!
I am trying to figure out how to get an image on the forum..
Logged
Valencia, Spain
Online Online
Edison Member
View Profile
You don't need limiting resistors for MOSFETs. Try it without them.
Logged
Offline Offline
Newbie
View Profile
I tried it without and no go.  I diconnected the gate and kept the source and drain connected to the projects grounds and power was getting through and I wasn't sure why..
Logged
Valencia, Spain
Online Online
Edison Member
View Profile
what's the voltage difference between source and gate when it's turned on?
Logged
Offline Offline
Newbie
View Profile
I'll have to check and post tonight.. Thanks for the input
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
What?  You shouldn't recommend this - a power MOSFET gate can be in range 1nF to 20nF, that's like a short-circuit load to an Arduino output pin on short timescales - they can only take 40mA abs max so a gate resistor of 150 ohms or so is recommended.  The datasheet seems to lack max load capacitance figures, but typical values are around 100pF or so for logic outputs in general, well below nanofarads.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
That MOSFET has a rather high Rds(on) of 0.2 ohms, so it will dissipate 800mW for a 2A load - it will run very hot - small heatsink highly recommended.  Its perfectly upto the job though as it is logic level and will only lose you 0.4V in voltage drop - clearly you have it wired up wrongly.
If you connect drain to source then you completely bypass the device, and if in that state the LEDs aren't lighting up properly its clearly nothing to do the the MOSFET!
Logged
Offline Offline
Edison Member
View Profile
Quote
It all depends.
Quote
They are specified to 40ma max but can deliver a lot more.
Quote
Again, it depends. But in general, for digital switchign applications, anything more than 47ohm here needs to be seriously evaluated, because of potential high switching loss it can cause.
Quote
Fig 5. And the gate charge, a far more useful figure than gate capacitance, is specified right on the 1st page.
Quote
Typical gate capacitance for a to220/to3p mosfet is 2-3nf.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
No, I mean the max capacitance load for the Arduino !!!!   And MOSFET gate capacitance varies with transconductance, I've one with 25nF gate capacitance for instance.  300A rating too smiley-wink
Logged
Offline Offline
Edison Member
View Profile
Quote
I have never paid any attention to that but most digital devices are specified with a 7 - 15pf Cl. Load capacitance isn't as big an issue with an output pin with substantial output resistance. It does matter significantly in a read-modify-write operation.
Quote
Driving something like that would be a challenge, for sure.
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
That's not the best MOSFET around [might get a little hot], but all in all, the ckt should work
perfectly fine as per the schematic. For low-frequency on-off switching, the resistor values
will be ok. You want the 10K pulldown to keep the load turned off during initial bootup
by the Arduino.
IOW, everything looks ok per the schematic, so 95% likelihood you have it wired wrong.
Logged
Kitchen-Sink Arduino-compatible boards
Valencia, Spain
Online Online
Edison Member
View Profile
I was getting to that...first we have to get them to light up "dimly" ;-)
Logged
Pages: [1] 2   Go Up
Print
Jump to:
