Topic: DAC support (Read 33700 times) previous topic - next topic
smay4finger
Hey there,
I tried the DACC on the Arduino Due, but it doesn't work as expected. I used the function analogWrite() for setting a new DAC value. The following code will work as expected:
Code: [Select]
byte value;
  analogWrite(DAC0, value++);
Same applies if you replace DAC0 with DAC1. For some unknown reason, I couldn't get both DACs to work simultaneously. The following code does not work:
Code: [Select]
byte value;
  analogWrite(DAC1, value * 2);
I think it has something to do with the code in hardware/arduino/sam/cores/arduino/wiring_analog.c. In the function analogWrite() there is the following lines:
Code: [Select]
// Write user value
ulValue = mapResolution(ulValue, _writeResolution, DACC_RESOLUTION);
dacc_write_conversion_data(DACC_INTERFACE, ulValue);
I'm missing the channel selection before writing conversion data. Did someone else use the DACs before with analogWrite()? Is the reported behaviour bug or feature?
mfg, Stefan.
cmaglie
smay4finger,
I fear that you're right, the analogWrite on DACs didn't work if you write on both DACs.
I don't know why, but seems that nobody (including me) ever dreamed to test BOTH channels together.
I'll put the fix to this in the to-do list, before the next beta release 1.5.1 (that is very close).
C
C.
smay4finger
#2
Nov 01, 2012, 07:20 pm Last Edit: Nov 01, 2012, 07:22 pm by smay4finger Reason: 1
Fix was trivial. Please find attached the patch for wiring_analog.c. Should I make bug report?
mfg, Stefan.
cmaglie
smay4finger,
thank for the patch I'm testing it in the next hours, in case may you open a pull request on github so i can merge it?
C
C.
Federico_Vanzati
I tested your patch and I think it works!
I attach a sketch that generates a sine wave on both the DAC outputs phase shifted of pi. To prove I add  the screen capture of the oscilloscope.
+1 Karma is deserved :)
F
smay4finger
I made a bug report here: http://code.google.com/p/arduino/issues/detail?id=1092
Please use the patch attached to the ticket. There is also a bugfix regarding corruption of the data register, when writing too fast.
cmaglie
C.
parasound
"I tried the DACC on the Arduino Due, but it doesn't work as expected. I used the function analogWrite() for setting a new DAC value. The following code will work as expected:"
Code: [Select]
byte value;
Hello, when i test the DAC on the DUE i measured an Outputvoltage from 0,55V (value 0) to 2,77V (value 255). I thought the DAC has a range from 0V to 3,3V?! Do anybody knows more or can help me?
greets
parasound
andy_g
"Hello, when i test the DAC on the DUE i measured an Outputvoltage from 0,55V (value 0) to 2,77V (value 255). I thought the DAC has a range from 0V to 3,3V?! Do anybody knows more or can help me?"
Hi all!
I would be interested in this too. Could not figure out yet why DAC range ist approx. 0,54V - 2.74V (both channels).
andy_G
wibauxl
Hi parasound and andy_g,
I could find no information about the DAC range in the SAM3X datasheet.
But on page 1059 of SAM3S datasheet, it is said that the voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF.
So I suspect, the same applies to SAM3U, and range is 1/6 x 3.3V = 0.55V to 5/6 x 3.3V = 2.75V, which is verified by your measures.
wibauxl
parasound
Ok.
Thank you wibauxl.
retrolefty
#11
Nov 12, 2012, 03:16 pm Last Edit: Nov 12, 2012, 04:24 pm by retrolefty Reason: 1
wibauxl
That seems pretty limiting. You mean one can't measure output signals between below .55 volt? There must be more to the subject then that?
Lefty
mbanzi
@retrolefty
We're talking about the DAC here. The ADC works at voltages below 0.55v.
As far as the DAC is concerned it's a pity to have such limits but I guess for audio applications there are way to circumvent the issue.
m
retrolefty
#13
Nov 12, 2012, 04:30 pm Last Edit: Nov 12, 2012, 04:34 pm by retrolefty Reason: 1
@retrolefty
m
Well I don't yet own a Due and not up to the task just yet of taking on the huge datasheet for this uP, but they must talk about this range restriction if indeed it's a hardware based restriction. I just find it very hard to except at this time that there is a legitimate reason for this. I guess it could be compensated for with external op-amp with a -.55v offset, but still there just must be more to this subject then 'that's just the way it is'? It's really not a problem for audio type applications as one could just capacitance couple the signal, but for precision DC DAC applications, not being able to reach ground potential is a pretty big deal, no?
Lefty
andy_g
...what would also make sense resolution-wise: LSB seems to be 0.5mV (measured) which is in line with wibauxl's theory ((2.75-0.55)/4096=0.537mV). This DAC behaviour -and te lack of it's documentation- is a little odd to my opinion, but at least there's an explanation that makes sense.
MANY THANKS FOR ALL YOUR INPUTS!!
andy_g
