Topic: DAC support (Read 32511 times) previous topic - next topic
mbanzi
andy_g
The Due is still in beta, there is still work to be done on the documentation.
m
cmaglie
I could find no information about the DAC range in the SAM3X datasheet.
But on page 1059 of SAM3S datasheet, it is said that the voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF.
So I suspect, the same applies to SAM3U, and range is 1/6 x 3.3V = 0.55V to 5/6 x 3.3V = 2.75V, which is verified by your measures.
I've just checked with Atmel support and they confirm that SAM3S and SAM3X features the same DAC IP, what you have measured is correct.
C.
Nantonos
As far as the DAC is concerned it's a pity to have such limits but I guess for audio applications there are way to circumvent the issue.
Yes, for audio applications, if voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF then you use a differential op-amp with the second input connected to (1/2) x VADVREF - though it would require a symmetric power supply. Or just use a DC blocking capacitor.
It is a surprising limitation for other uses, though.
vdorr
Hello,
i'am experiencing the same problem as smay4finger described in original post, using this code:
Code: [Select]
  analogWriteResolution(12);
  analogWrite(DAC0, 4095);
  analogWrite(DAC1, 4095);
void loop(){}
however, this code set correct output values:
Code: [Select]
  delay(2);
  analogWrite(DAC0, 2047);
  analogWrite(DAC1, 1023);
i suspect problem in this line in wiring_analog.c:
Code: [Select]
while ((dacc_get_interrupt_status(DACC_INTERFACE) & DACC_ISR_TXRDY) == 0);
but you guys know better.
Regards,Vladimir
jgmdavies
@vdorr
Are you using the amended code (Reply #2)?
Jim
vdorr
@jgmdavies
Hi, i'm using Arduino 1.5.1 which allready contains this patch.
V.
jgmdavies
#21
Jan 05, 2013, 03:16 pm Last Edit: Jan 05, 2013, 03:54 pm by jgmdavies Reason: 1
@vdorr
OK, I'm using 1.5.1r2.
The following works as expected here, giving independent control of the two DACs:
Code: [Select]
       while (true)
           analogWrite(DAC0, 240);
           delayMicroseconds(200);
           for (int i = 0; i < 8; i++)
               analogWrite(DAC1, 240);
               delayMicroseconds(20);
               analogWrite(DAC1, 120);
               delayMicroseconds(80);
           analogWrite(DAC0, 0);
           analogWrite(DAC1, 0);
           delay(9);
Several people in this forum seem to have had trouble and have possibly blown their DAC output(s) by following an Audio example with a loudspeaker (which I haven't tried).
For anyone following with an 'early production' Due like me, please note that the constant 'DAC0' (66) corresponds to pin 'DAC2' on the board header, and 'DAC1' (67) corresponds to pin 'DAC1'.
Attached are screenshots from a Rigol scope. N.B. I'm using x10 probes.
HTH
Jim
vdorr
@jgmdavies
i guess you are writing DAC in loop() but my (non-working) example was writing DAC in setup(), your code also has delay before writing second DAC channel, just like my second (working) example. In my opionion, there is bug in analogWrite(), related to initialization of DAC.
V.
jgmdavies
Hi V,
The following works as expected here, with outputs as per the earlier scope 'screenshots':
Code: [Select]
       while (true)
            delay(9);
What do you get?
Jim
jgmdavies
Hi V,
And commenting out the initial delay like so:
Code: [Select]
       while (true)
            delay(9);
gives the outputs shown below.
Jim
vdorr
@jgmdavies
I tried your code and from what i can tell (using Velleman HPS5), it works as expected, BUT it is equivalent to example from my first post which works as expected:
Code: [Select]
analogWrite(DAC0, 255);
analogWrite(DAC1, 255);
void loop(){}
both outputs are at 2.8V, what is NOT working is this piece of code:
Code: [Select]
void loop(){}
using this code DAC0 is at 0.54V and DAC1 at 2.8V
V.
vdorr
@jgmdavies
Insertion of some delay between first two writes is perfectly acceptable workaround for me, but IMO this behaviour is bug and should be fixed. Am i crying on wrong place(forum)?
jgmdavies
@vdorr
OK, I've caught up with you now!
And I agree, it seems to be a bug.  The delay between the writes in start() needs to be at least 30 us on mine (using the default 8 bit resolution).
Jim
vdorr
@jgmdavies
This modification seem to fix this buggy behaviour:
Code: [Select]
diff --git a/hardware/arduino/sam/cores/arduino/wiring_analog.c b/hardware/arduino/sam/cores/arduino/wiring_analog.c
index 58bd87a..97f50e8 100644
--- a/hardware/arduino/sam/cores/arduino/wiring_analog.c
+++ b/hardware/arduino/sam/cores/arduino/wiring_analog.c
@@ -243,8 +243,8 @@ void analogWrite(uint32_t ulPin, uint32_t ulValue) {
                        // Write user value
                        ulValue = mapResolution(ulValue, _writeResolution, DACC_RESOLUTION);
-                       while ((dacc_get_interrupt_status(DACC_INTERFACE) & DACC_ISR_TXRDY) == 0);
                        dacc_write_conversion_data(DACC_INTERFACE, ulValue);
+                       while ((dacc_get_interrupt_status(DACC_INTERFACE) & DACC_ISR_EOC) == 0);
                        return;
also with this change should desired value be on output pin by the time analogWrite() exits. Opinions?
V.
jgmdavies
@vdorr
Looks good to me.  I repeated the basic test in start() with no delays and now it's fine, and my other tests are still good.
I think the person to discuss this with is cmaglie in this forum.
Thanks,
Jim
