Topic: DAC support (Read 32403 times) previous topic - next topic
cmaglie
@vdorr,
thank you!
If you can open a pull request it would be perfect, otherwise I'll apply the fix by myself.
C.
vdorr
@cmaglie
I believe i've just opened pull request for this issue.
V.
cmaglie
Yes, this is the preferred way to submit patches, thanks.
https://github.com/arduino/Arduino/pull/1202
C.
joker
Thanks for saving my nerves!  :smiley-mr-green:
rgbp
Hi Guys,
Is it possible to change the DAC resolution using the dacc_write_conversion_data(DACC_INTERFACE, value);?
It's always using 12 bits, even if I change using that command: analogWriteResolution(8);.
Is it seem the analogWriteResolution(8); only works when we write a value using analogWrite(DAC0, value);
Thanks
Jorgeard
Hi. I'm trying to use the DAC from my due to make a square wave. After analogWrite(DAC0,value), the output voltage won't reach 0V again. I know that the voltage output will always be between 0.55 and 2.75V, but i really need 0V... There is a way to turn off the DAC0? I've tried digitalWrite(DAC0,LOW) with and without pinmode() function.
Best regards,
Jorge
russellcrow
How to get rid of the 0.55 Vdc from the DAC output---
You will have to waste an amplifier on this to do it right, otherwise a series capacitor will do the trick.  I'll show you in text so everyone can see it:
  ----|(----      use a nice big capacitor; 47uf will pass just about all frequencies, 0.047pf will block all frequencies.
Better to use an amplifier, Freescale has one that works in front of a comparator; here's the link:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3552.pdf
Best regards
