Topic: INTERFACING NDIR CO2 MODULE WITH ARDUINO (Read 8516 times) previous topic - next topic
vmandin
Good day everyone!
Has anyone tried interfacing an NDIR CO2 module to arduino?
I'm trying to use a Telaire T6004 CO2 module that I ordered from the net. I want to get analog values so that I could make a monitoring system. WHAT PINS SHOULD I USE? Is the method of getting values from this sensor similar with a simple voltage divider using potentiometer? Im new with arduino but I need to learn it quickly. I would be grateful if someone would help me in understanding the requirements in order to communicate this NDIR CO2 module with arduino. Attached is a product description of the module.
Also, i have seen a youtube video that was using the same sensor module, and it made me realize that it could really be possible, unfortunately, there was no clear description on how he was able to interface and code it with his arduino.
Here's the youtube link that I saw:
http://www.youtube.com/watch?v=gBtDGUB8HO8&feature=BFa&list=LLr0jPRmT8T1hsb20X1gxpCw
dc42
From the datasheet it looks to me that the AVOUT pin provides 0 to 4V depending on the level of CO2. So you could connect that pin directly to an analog input. The only other pins I think you need to connect are +5V and ground.
robtillaart
Rob Tillaart
vmandin
How can I calculate PPM. If my analog output voltage is 0-4V? and the sensitivity of the CO2 sensor is 0-2000PPM? Pls help!
dc42
If 0V is 0ppm and 4V is 2000ppm and the device is linear and you are using the standard 5V analog reference, then:
  ppm = (analog_reading * 2000 * 5)/(1024 * 4)
You'll need to use unsigned long arithmetic to avoid overflow, e.g. this code:
  unsigned int ppm = ((unsigned long)analogRead(pin) * 2500)/1024;
vmandin
Thank u so much sir. How about if 0ppm is 1V and 2000ppm is 4V? how is that calculated?
Riva
dc42
ppm = (analog_reading * 3000 * 5)/(1024 * 4) - 1000
However, if your 5V supply (the default analog reference) is not very accurate then you will have a significant zero error. If the sensor has a digital output, it would be better to use that.
vmandin
Yes sir, the sensor has a digital output. What exactly is the difference in measurements if I use the digital or analog? And how is it done?
Riva
The device seems to have analogue, serial and SPI interfaces. The data sheet says...
SPI/Microwire or UART @9600 baud
(Please call for detailed protocol specification)
vmandin
Yes, its on the data sheet. I just don't know how to use it yet. I would like to know how accurate is the digital output than the analog.
Riva
Reading serial would be relatively easy so just setup a test bench where your reading the analogue pin and serial data as close to the same time as possible and compare the results over the range your looking for. You will then know how good your analogue calculations are.
koaiwi
Hi Riva. I can see the spi pins marked in the documentation. Can you tell me which pin is the analog. Is it pin 4? Thanks.
Riva
Assuming your device is the same as this http://www.telaire.com/pdf/datasheets/module6004a.pdf then the datasheet shows pin 4 is the analogue out. FYI pin 10 is TX and pin 11 is RX and the data sheet says 9600 boud if you want to compare to serial. To read SPI your probably going to have to ask the manufactures as you will need register information to do this.
