Topic: [HELP]IR proximity Sensor measuring Depth water (Read 965 times) previous topic - next topic
alvinford
Help,
can an Infrared Proximity Sensor measure depth of water more or less 2ft??
I found this:
http://philippines.rs-online.com/web/p/photoelectric-sensors/6666564/
Can you suggest something for me, thanks//
robtillaart
Quote
it works better if you can let a reflector float on the water. Just let the sensor look through a pipe in which the reflector floats.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
alvinford
well my project is an ROV(remote operated Vehicle)particularly a "Boat" with a Sensor mounted to it,
Practically I need a sensing operation close to a fish finder's operation..
the problem with the fish finder is it's minimum detecting range whic is .6m which is too high for us..
Shallow water depth range sensing is enough for me up to 3cm up to 2m is enough..
any suggestion?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
