Topic: Port manipulation PINx commands with Arduino Due ? (Read 56220 times) previous topic - next topic
seppo
Hello!
are the port manipulation commands supported in Due ? I have used PINx  commands with Arduino Mega to read and write bytes instead of digitalRead() and -Write() ,
and would like to do the same with Due ,
and if byte (or word size 16 bits) simultaneous reading and writing is possible , how should the PIN command syntax be ?
BR,
Seppo
chrisbillington
I'm trying to work this out as well, at the moment I'm looking in arduino-1.5/hardware/arduino/sam/variants/arduino_due_x/variants.cpp and variants.h, but I haven't figured it out yet.
baltasar
Read here there some more info (all the way to the end): http://arduino.cc/forum/index.php/topic,129407.0.html
I'm also trying to do port manipulation.
chrisbillington
#3
Oct 31, 2012, 02:23 pm Last Edit: Oct 31, 2012, 02:54 pm by chrisbillington Reason: 1
It looks like you might be able to do:
REG_PIOx_ODSR = data_to_set;
to set output data, and:
input_data = REG_PIOx_PDSR;
to get input data, where x is A,B,C or D. The acronyms are "output data status register" and "pin data status register". You may first need to enable output by writing ones to PIOx_OWER (output write enable register). If you've already used standard arduino calls to set the pin in question to be an output, I think that's all you'll need to do. See page 646 of the datasheet for more info:
http://www.atmel.com/Images/doc11057.pdf
The registers all follow the same naming convention, it's always REG_PIOx_<whatever>, so it's easy to translate register names in the datasheet to variable names in your sketch.
I can't test as I don't have a Due yet, I'd love to know if this works though.
alvesjc
Hi.
Like Baltasar, I'm struggling with this issue also.
The compiler likes that method to deal with ports, but now I'm stuck after. It has something to do with pins_arduino.h.
When compiler gets this lines:
P_RS   = portOutputRegister(digitalPinToPort(RS));
B_RS   = digitalPinToBitMask(RS);
P_WR   = portOutputRegister(digitalPinToPort(WR));
B_WR   = digitalPinToBitMask(WR);
P_CS   = portOutputRegister(digitalPinToPort(CS));
B_CS   = digitalPinToBitMask(CS);
P_RST   = portOutputRegister(digitalPinToPort(RST));
B_RST   = digitalPinToBitMask(RST);
It says:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp: In constructor 'UTFT::UTFT(byte, int, int, int, int, int)':
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:159: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:160: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:161: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:162: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:163: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:164: error: base operand of '->' has non-pointer type 'const PinDescription'
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:165: error: base operand of '->' has non-pointer type 'const PinDescription'
This is pointing to file variant.cpp, to this function:
* Pins descriptions
extern const PinDescription g_APinDescription[]=
  // 0 .. 53 - Digital pins
The operand '->' is not seen inside the function, I don't understand what the compiler want.
Can someone help?
www.aqualedsource.com
chrisbillington
alvesjc,
I'm not sure what you're doing, but it looks like the functions you're calling expect pointers to PinDescriptions objects, and that you're giving them actual PinDescription objects rather than pointers. So the -> operator (which may be implicit in that function even though you can't see it) fails. See here for an explanation:
http://stackoverflow.com/questions/1238613/what-is-the-difference-between-the-dot-operator-and-in-c
So I can't tell from your code which variables are PinDescriptions, but if you put an ampersand in front of them, you'll be converting them to pointers and then the -> operator will work.
So if RS is a PinDescription, try digitalPinToPort(&RS).
alvesjc
Hi.
RS is a variable, basically, the pin corresponding to RS signal to TFT. RS is for example, PIN39, is passed when the lib is initialized:
class UTFT
   public:
      UTFT();
      UTFT(byte model, int RS, int WR,int CS, int RST, int SER=0);
RS is for exemple, 39.
chrisbillington
Hm. I'm not sure what's going on then. If you're just trying to read and write directly from ports, have you tried the method I suggested in reply #3?
alvesjc
While trying your sugestion, the errors are now:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:159: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:160: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:161: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:162: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:163: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:164: error: invalid types 'const PinDescription [][int*]' for array subscript
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:165: error: invalid types 'const PinDescription [][int*]' for array subscript
alvesjc
Yes, that method solved the compilation problem at least. I can't test it yet because the other errors.
But the port handling is now this:
void UTFT::LCD_Writ_Bus(char VH,char VL, byte mode)
switch (mode)
case 16:
#if defined(__SAM3X8E__)
//DB00 on PIN37 -> PIO_PC5
REG_PIOC_ODSR=(VL<<5) & 0x20;
//DB01 on PIN36 -> PIO_PC4
REG_PIOC_ODSR=(VL<<3) & 0x10;
//DB02 on PIN35 -> PIO_PC3
REG_PIOC_ODSR=(VL<<1) & 0x08;
//DB03 on PIN34 -> PIO_PC2
REG_PIOC_ODSR=(VL>>1) & 0x04;
//DB04 on PIN33 -> PIO_PC1
REG_PIOC_ODSR=(VL>>3) & 0x02;
//DB05 on PIN32 -> PIO_PD10
REG_PIOD_ODSR=(VL<<5) & 0x400;
//DB06 on PIN31 -> PIO_PA7
REG_PIOA_ODSR=(VL<<1) & 0x80;
//DB07 on PIN30 -> PIO_PD9
REG_PIOD_ODSR=(VL<<2) & 0x200;
//DB08 on PIN22 -> PIO_PB26
REG_PIOB_ODSR=(VH<<26) & 0x4000000;
//DB09 on PIN23 -> PIO_PA14
REG_PIOA_ODSR=(VH<<13) & 0x4000;
//DB10 on PIN24 -> PIO_PA15
REG_PIOA_ODSR=(VH<<13) & 0x8000;
//DB11 on PIN25 -> PIO_PD0
REG_PIOD_ODSR=(VH>>3) & 0x01;
//DB12 on PIN26 -> PIO_PD1
REG_PIOD_ODSR=(VH>>3) & 0x02;
//DB13 on PIN27 -> PIO_PD2
REG_PIOD_ODSR=(VH>>3) & 0x04;
//DB14 on PIN28 -> PIO_PD3
REG_PIOD_ODSR=(VH>>3) & 0x08;
//DB15 on PIN29 -> PIO_PD6
REG_PIOD_ODSR=(VH>>1) & 0x40;
#endif
pulse_low(P_WR, B_WR);
break;
void UTFT::_set_direction_registers(byte mode)
if (mode==16)
REG_PIOA_OWER=0xc080; //PA7,PA14,PA15 enable
REG_PIOB_OWER=0x4000000; //PB26 enable
REG_PIOC_OWER=0x3e; //PC1 - PC5 enable
REG_PIOD_OWER=0x64f; //PD0-3,PD6,PD9-10 enable
#endif
After this, it stoped complaining about the PORT defenitions, so I guess you'r right! ;)
seppo
Hi!
tested the syntax :
int input_data = REG_PIOD_PDSR;
and works ok and the command reads the D port ok with this one command, tested by changing all the input states,
will be testing the A,B and C ports and  outputs tomorrow , will report more then,
Chris , thanks for info !
BR,
Seppo
alvesjc
Hi.
Ok, I've figured out what is wrong.
Looking to arduino mega pins_arduino.h we find this:
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
// PORTLIST
PE , // PE 0 ** 0 ** USART0_RX
PE , // PE 1 ** 1 ** USART0_TX
PE , // PE 4 ** 2 ** PWM2
PE , // PE 5 ** 3 ** PWM3
PG , // PG 5 ** 4 ** PWM4
PE , // PE 3 ** 5 ** PWM5
PH , // PH 3 ** 6 ** PWM6
PH , // PH 4 ** 7 ** PWM7
PH , // PH 5 ** 8 ** PWM8
PH , // PH 6 ** 9 ** PWM9
PB , // PB 4 ** 10 ** PWM10
PB , // PB 5 ** 11 ** PWM11
PB , // PB 6 ** 12 ** PWM12
PB , // PB 7 ** 13 ** PWM13
PJ , // PJ 1 ** 14 ** USART3_TX
PJ , // PJ 0 ** 15 ** USART3_RX
PH , // PH 1 ** 16 ** USART2_TX
PH , // PH 0 ** 17 ** USART2_RX
PD , // PD 3 ** 18 ** USART1_TX
PD , // PD 2 ** 19 ** USART1_RX
PD , // PD 1 ** 20 ** I2C_SDA
PD , // PD 0 ** 21 ** I2C_SCL
PA , // PA 0 ** 22 ** D22
PA , // PA 1 ** 23 ** D23
PA , // PA 2 ** 24 ** D24
PA , // PA 3 ** 25 ** D25
PA , // PA 4 ** 26 ** D26
PA , // PA 5 ** 27 ** D27
PA , // PA 6 ** 28 ** D28
PA , // PA 7 ** 29 ** D29
PC , // PC 7 ** 30 ** D30
PC , // PC 6 ** 31 ** D31
PC , // PC 5 ** 32 ** D32
PC , // PC 4 ** 33 ** D33
PC , // PC 3 ** 34 ** D34
PC , // PC 2 ** 35 ** D35
PC , // PC 1 ** 36 ** D36
PC , // PC 0 ** 37 ** D37
PD , // PD 7 ** 38 ** D38
PG , // PG 2 ** 39 ** D39
PG , // PG 1 ** 40 ** D40
PG , // PG 0 ** 41 ** D41
PL , // PL 7 ** 42 ** D42
PL , // PL 6 ** 43 ** D43
PL , // PL 5 ** 44 ** D44
PL , // PL 4 ** 45 ** D45
PL , // PL 3 ** 46 ** D46
PL , // PL 2 ** 47 ** D47
PL , // PL 1 ** 48 ** D48
PL , // PL 0 ** 49 ** D49
PB , // PB 3 ** 50 ** SPI_MISO
PB , // PB 2 ** 51 ** SPI_MOSI
PB , // PB 1 ** 52 ** SPI_SCK
PB , // PB 0 ** 53 ** SPI_SS
PF , // PF 0 ** 54 ** A0
PF , // PF 1 ** 55 ** A1
PF , // PF 2 ** 56 ** A2
PF , // PF 3 ** 57 ** A3
PF , // PF 4 ** 58 ** A4
PF , // PF 5 ** 59 ** A5
PF , // PF 6 ** 60 ** A6
PF , // PF 7 ** 61 ** A7
PK , // PK 0 ** 62 ** A8
PK , // PK 1 ** 63 ** A9
PK , // PK 2 ** 64 ** A10
PK , // PK 3 ** 65 ** A11
PK , // PK 4 ** 66 ** A12
PK , // PK 5 ** 67 ** A13
PK , // PK 6 ** 68 ** A14
PK , // PK 7 ** 69 ** A15
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
// PIN IN PORT
_BV( 0 ) , // PE 0 ** 0 ** USART0_RX
_BV( 1 ) , // PE 1 ** 1 ** USART0_TX
_BV( 4 ) , // PE 4 ** 2 ** PWM2
_BV( 5 ) , // PE 5 ** 3 ** PWM3
_BV( 5 ) , // PG 5 ** 4 ** PWM4
_BV( 3 ) , // PE 3 ** 5 ** PWM5
_BV( 3 ) , // PH 3 ** 6 ** PWM6
_BV( 4 ) , // PH 4 ** 7 ** PWM7
_BV( 5 ) , // PH 5 ** 8 ** PWM8
_BV( 6 ) , // PH 6 ** 9 ** PWM9
_BV( 4 ) , // PB 4 ** 10 ** PWM10
_BV( 5 ) , // PB 5 ** 11 ** PWM11
_BV( 6 ) , // PB 6 ** 12 ** PWM12
_BV( 7 ) , // PB 7 ** 13 ** PWM13
_BV( 1 ) , // PJ 1 ** 14 ** USART3_TX
_BV( 0 ) , // PJ 0 ** 15 ** USART3_RX
_BV( 1 ) , // PH 1 ** 16 ** USART2_TX
_BV( 0 ) , // PH 0 ** 17 ** USART2_RX
_BV( 3 ) , // PD 3 ** 18 ** USART1_TX
_BV( 2 ) , // PD 2 ** 19 ** USART1_RX
_BV( 1 ) , // PD 1 ** 20 ** I2C_SDA
_BV( 0 ) , // PD 0 ** 21 ** I2C_SCL
_BV( 0 ) , // PA 0 ** 22 ** D22
_BV( 1 ) , // PA 1 ** 23 ** D23
_BV( 2 ) , // PA 2 ** 24 ** D24
_BV( 3 ) , // PA 3 ** 25 ** D25
_BV( 4 ) , // PA 4 ** 26 ** D26
_BV( 5 ) , // PA 5 ** 27 ** D27
_BV( 6 ) , // PA 6 ** 28 ** D28
_BV( 7 ) , // PA 7 ** 29 ** D29
_BV( 7 ) , // PC 7 ** 30 ** D30
_BV( 6 ) , // PC 6 ** 31 ** D31
_BV( 5 ) , // PC 5 ** 32 ** D32
_BV( 4 ) , // PC 4 ** 33 ** D33
_BV( 3 ) , // PC 3 ** 34 ** D34
_BV( 2 ) , // PC 2 ** 35 ** D35
_BV( 1 ) , // PC 1 ** 36 ** D36
_BV( 0 ) , // PC 0 ** 37 ** D37
_BV( 7 ) , // PD 7 ** 38 ** D38
_BV( 2 ) , // PG 2 ** 39 ** D39
_BV( 1 ) , // PG 1 ** 40 ** D40
_BV( 0 ) , // PG 0 ** 41 ** D41
_BV( 7 ) , // PL 7 ** 42 ** D42
_BV( 6 ) , // PL 6 ** 43 ** D43
_BV( 5 ) , // PL 5 ** 44 ** D44
_BV( 4 ) , // PL 4 ** 45 ** D45
_BV( 3 ) , // PL 3 ** 46 ** D46
_BV( 2 ) , // PL 2 ** 47 ** D47
_BV( 1 ) , // PL 1 ** 48 ** D48
_BV( 0 ) , // PL 0 ** 49 ** D49
_BV( 3 ) , // PB 3 ** 50 ** SPI_MISO
_BV( 2 ) , // PB 2 ** 51 ** SPI_MOSI
_BV( 1 ) , // PB 1 ** 52 ** SPI_SCK
_BV( 0 ) , // PB 0 ** 53 ** SPI_SS
_BV( 0 ) , // PF 0 ** 54 ** A0
_BV( 1 ) , // PF 1 ** 55 ** A1
_BV( 2 ) , // PF 2 ** 56 ** A2
_BV( 3 ) , // PF 3 ** 57 ** A3
_BV( 4 ) , // PF 4 ** 58 ** A4
_BV( 5 ) , // PF 5 ** 59 ** A5
_BV( 6 ) , // PF 6 ** 60 ** A6
_BV( 7 ) , // PF 7 ** 61 ** A7
_BV( 0 ) , // PK 0 ** 62 ** A8
_BV( 1 ) , // PK 1 ** 63 ** A9
_BV( 2 ) , // PK 2 ** 64 ** A10
_BV( 3 ) , // PK 3 ** 65 ** A11
_BV( 4 ) , // PK 4 ** 66 ** A12
_BV( 5 ) , // PK 5 ** 67 ** A13
_BV( 6 ) , // PK 6 ** 68 ** A14
_BV( 7 ) , // PK 7 ** 69 ** A15
These two arrays are the key to allow to easily choose any pin and immediately know is port and bit number to build a mask.
These arrays are note present in Due pins_arduino.h (that links to variant.cpp).
If I force the pins and get their port and bit, this lib will certainly work, but at the cost of loosing flexibility.
Is there any problem about including this arrays with due pin tables to pins_arduino.h?
alvesjc
I think i've got a little more of this picture.
The compiler complains that:
When in the UTFT lib the compiler reaches the line 158:
Well, this calls from arduino.h the following:
#define digitalPinToPort(P)        ( g_APinDescription[P]->pPort )
g_APinDescription[] is one array of type "PinDescription" that is this struct in arduino.h:
/* Types used for the tables below */
typedef struct _PinDescription
  Pio* pPort ;
  uint32_t ulPin ;
  uint32_t ulPeripheralId ;
  EPioType ulPinType ;
  uint32_t ulPinConfiguration ;
  uint32_t ulPinAttribute ;
  EAnalogChannel ulAnalogChannel ; /* Analog pin in the Arduino context (label on the board) */
  EAnalogChannel ulADCChannelNumber ; /* ADC Channel number in the SAM device */
  EPWMChannel ulPWMChannel ;
  ETCChannel ulTCChannel ;
} PinDescription ;
This struct is instantiated then with:
/* Pins table to be instanciated into variant.cpp */
extern const PinDescription g_APinDescription[] ;
All this seems logical but it doesn't work.
Based on the info in this link:
http://cplusplus.syntaxerrors.info/index.php?title=Base_operand_of_arrow_has_non-pointer_type_%E2%80%98Foo%E2%80%99
I've tried to replace this:
with this:
#define digitalPinToPort(P)        ( g_APinDescription[P].pPort )
But then I have the following error:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: invalid conversion from 'volatile RwReg' to 'volatile uint8_t*'
RS is pin 38, and that is what is passed to the define.
Can someone help with this? I'm clueless....
westfw
I can't figure out what you are trying to do, or what you've done.  You keep posting segments of pins_arduino.h and variant.cpp, and never the code that you've actually written...
pins_arduino.h and variant.cpp are the modules that translate from the names that the Arduino environment uses (1, 2, 3, PIN_LED_13) to the addresses used by the CPU internally.  They have nothing to do with "direct port manipulation" except as way to identify which Arduino pins match up with which ports and bits.
The Arduino pin numbers are small and consecutive integers, while the ports are large 32bit addresses, and the bits are bit numbers.  In the Due implementation, the Arduino pin number is used as an index into an array of structures with various information about the pin/port/bit/function.  In the MEGA implementation, the pin number is used as an index into various parallel simple arrays that each convey part the same set of information.  It's part of the power of the "variant" code setup that two different boards can have substantially different implementations.
And yes, to do direct port manipulation, you give up a LOT of the flexibility that you'd get from using the Arduino pin names.
alvesjc
Hi Westfw.
What I'm trying to do, is to port UTFT library from MEGA to work with DUE. This library is from Henning Karlsen, but since e doesn't have a DUE at the moment, he can't work on the lib now.
The original library is here:
http://www.henningkarlsen.com/electronics/library.php?id=51
What is needed to port is all the low level functions that deal with ports. Part of that is done following reply #3, that is, the TFT data bus. Now I'm stuck in the control pins of the TFT.
You can find attached the library with the changes I've made so far.
My last post shows the point were I'm bumping now.
The code that is failing is in the file "utft.cpp" in the lines mentioned in last post.
Can you or someone else help me out with this?
Thank you.
BR,
Joao
