Topic: SOLVED: Interrupt queuing (Read 3468 times) previous topic - next topic
jtw11
Oct 30, 2012, 06:54 pm Last Edit: Oct 30, 2012, 07:47 pm by jtw11 Reason: 1
I've searched for this, but cannot find a definative answer.
Say for example, a rising interrupt is used to increment a counter, if in the loop of a code the interrupt is detached to prevent another interrupt disrupting a calculation, then reattached - what happens if that interrupt pin goes high during the period it is detached?
When it becomes reattached, is there a 'pending' or 'queued' interrupt that is then serviced? If not, is there any way to do this?
PaulS
Yes, the interrupts are queued. But, only one of each kind. If there is more than one of a given kind, the extra(s) are ignored.
cmagagna
The event is lost. There's no per-event queueing.
Write your interrupt handler(s) to be as small & fast as possible so these conditions won't occur. Set flags, push entries on a private stack or make entries in an array, etc. inside the interrupt handler to log the event, then have the main loop process the events as it can.
Good luck!
DuaneB
A number of libraries make a point of clearing pending interrupt flags before they start, attachInterrupt probably does this which is what might be causing your confusion.
You do not need to attach/detach the interrupt, you can simply disable interrupts temporarily. Any interrupts which happen while disabled will be held in a pending state and processed when interrupts are re enabled, this is standard practice for accessing shared variables etc.
loop()
nointerrupts(); // disable interrupts while we do something sensitive like access a shared variable which is also accessed in the interrupt
interrupts(); // reenable interrupts, any that occured between nointerrupts and now, will be serviced now.
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
jtw11
#4
Oct 30, 2012, 07:09 pm Last Edit: Oct 30, 2012, 07:13 pm by jtw11 Reason: 1
Thanks very much, I will use the interrupts(); method. However, will there indeed only be 1 queued interrupt allowed, or more? There seems to be conflicting replies.
Coding Badly
Normally, no.  attachInterrupt has (had?) a bug that works the way you've described.
Coding Badly
Each interrupt source has a queue depth of one.  (Except in one reasonable case where the depth is zero.)
jtw11
Interrupt source being that specific interrupt pin?
Coding Badly
Not exactly.  For a given pin, there could be several interrupt sources.  All pins support "pin change" interrupts; that is one source.  A few pins support "external interrupts"; that is another source.  (attachInterrupt uses "external interrupts")
jtw11
I see, so if there were two external interrupts, only one queue event would be logged even though there are 2 requesting a log (if for example, they were)?
Also, what is a pin change interrupt? Is that adding another interrupt pin using the PinChangeInt library?
Coding Badly
No.  Each is a separate source.
It's similar to CHANGE available for external interrupts (attachInterrupt( pin, CHANGE );).
Yes.  But only for CHANGE.  LOW, RISING, and FALLING are not available (but can be simulated and are simulated in one of the pin-change interrupt libraries).
jtw11
I see - once again, many thanks for all the quick replies.
