Pages: [1] 2   Go Down
Author Topic: 4 bit LCD library and Hitachi HD44780 compatible display  (Read 1484 times)
i have connected a compatible display to my arduino
using arduino ide 1.01
the display is a CU20025ECPB-U1J
only the following pins are connectedno other pins are connected
lcd     to   UNO
pin 1 ---   ground
pin 2 ---   5v
pin3 --- not con------contrast
pin 4 ---   uno pin 7  --- RS
pin5 --- not con ---- RW
pin 6---    uno pin 6  --- enable
pin7 --not connect ---db0
pin8 -- not conn --- db1
pin 9 --- not conn  --- db2
pin10 --- not conn  --- db3
pin 11 --- uno pin 5 ---- db4
pin 12 --- uno pin 4 ---- db5
pin 13 ---  uno pin 3 ---- db6
pin 14 --- uno pin 2 --- db7
the proble is hello, world is displayed as    h e l l o ,  w o r  (with spaces)
ok here are the exect printing and location
display location
 h e l l o ,   w o r
any idea how i can fix this
here is the code
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  //lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  //lcd.print(millis()/1000);
« Last Edit: October 30, 2012, 08:34:21 pm by zarobhr » Logged
Western New York, USA
What we really need to know is:
1.  The specific display that you are using.
2.  The specific version of the Arduino IDE that you are using.
3.  The specific library that you are using.
4.  ALL of the connections to your display (did you connect pins 3 and 5?).
5.  ALL of the code that you are using.
6.  The exact contents of the display that resulted (did the quotation marks and exclamation point really disappear?).
7.  How you managed to get 22 characters displayed on a 20 character wide display.
Then we may be able to give some specific help.
Don
« Last Edit: October 30, 2012, 07:18:08 pm by floresta » Logged
Don
modified above post to reflect the questions
Central MN, USA
What about #4?
What about #4?
sry i only but connected ones here are the non connected ones
3- contrast
5-RW
7 DB0
8 DB1
9 DB2
10 DB3
This is really not a good procedure since the reasons for my original questions are now no longer part of the thread.  It makes me look like an idiot and it makes it hard for anyone who reads this in the future to follow the entire troubleshooting procedure.
Your answer to #6 does not mention anything about the second row of information.  Did anything appear?  Were there extra spaces?
I can't believe that your display shows anything with pins 3 and/or 5 floating.
Don
Don
sry for the modification i havent posted much here.
as for second row i did not send anything to  second row in the test
now it get interesting
first i changed  the code to
lcd.begin(20, 2);
  //lcd.setCursor(0, 0);
  lcd.print("byebye, world!");
this resulted in the first line still messed up but the second line perfect
next changed to
lcd.begin(20, 2);
  lcd.setCursor(0, 0); //first line
  lcd.setCursor(0, 1); //second line
this resulted in first line perfect and second line with spaces between each character sent
Let's get pins 3 and 5 taken care of first.  Most displays are blank with pin 3 floating (unconnected) and they will show unpredictable behavior with pin 5 floating.  Your display seems to behaving somewhat unpredictably.
Don
Can you point us to some documentation for this display.  As far as I can tell it is a VFD display, not an LCD so that changes things a bit.
Don
Don
data sheet http://www.datasheetarchive.com/CU20025ECPB-U1J-datasheet.html
there are also other posts on the forum that i read where people are using the arduino library for the vfd. it is an lcd compatible vfd
United Kingdom
As floresta says, leaving the RW pin floating is asking for trouble. You need to connect it to ground.
RW is now connected to ground, same results
Is jumper link J2 soldered or open?
Don
Don
i will check but i have been experimenting and here is what i found out(work arounds)
basically if i issue the lcd.setCursor command twice except the very first time, everytime it is used then everything works fine
example one
 and shows the time.
  The circuit:
 * 10K resistor:
 by David A. Mellis
 by Tom Igoe
 by Tom Igoe
  lcd.begin(20, 2);
  //delay (10);
  lcd.setCursor(0, 1); // added second time here and it now works
  //lcd.print("hello, world!");
  //delay(50);
example 2
  LiquidCrystal Library - Autoscroll
 This sketch demonstrates the use of the autoscroll()
 and noAutoscroll() functions to make new text scroll or not.
 The circuit:
 * 10K resistor:
 by David A. Mellis
 by Tom Igoe
 by Tom Igoe
 http://arduino.cc/en/Tutorial/LiquidCrystalAutoscroll
  lcd.begin(20,2);
  // set the cursor to (0,0):
  lcd.setCursor(0, 0); // added repeat
  // print from 0 to 9:
  for (int thisChar = 0; thisChar < 10; thisChar++) {
   lcd.print(thisChar);
  // set the cursor to (16,1):
  lcd.setCursor(20,1);
  lcd.setCursor(20,1); //added repeat
  // set the display to automatically scroll:
  lcd.autoscroll();
  // turn off automatic scrolling
  lcd.noAutoscroll();
  // clear screen for the next loop:
  lcd.clear();
Don
it looks like it is open
Pages: [1] 2   Go Up
