Topic: Powering an Arduino Nano (Read 845 times) previous topic - next topic
markpeace
Hi all,
I'm building a project using an Arduino Nano, and I can't quite work out how to power it (other than USB). Elsewhere in the project, I'm powering a pump using a 12V adapter, capable of 3amps. The pump pulls a maximum of about 1.2amps - so I'm wondering if I can also rig the nano up to this. Hunting around the interwebs, I find that ...
Quote
The Arduino Nano can be powered via the Mini-B USB connection, 6-20V unregulated external power supply (pin 30), or 5V regulated external power supply (pin 27). The power source is automatically selected to the highest voltage source.
... I'm reading that this means I can run power through pin 30. But, I'm left with two questions ...
1. Where the devil is Pin 30? It's not easily identifiable from the board.
2. Do I just connect ground on the board up to ground on the supply?
Thanks for any help.
Mark.
runaway_pancake
See
http://ep.yimg.com/ca/I/yhst-27389313707334_2230_47792144
Aren't the pins on yours labelled as they are in this picture?
Quote
Pin 30 (Vin) is there right next to the ICSP header and Gnd is right next to it.
Quote
Yes.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
markpeace
Great - cheers. I suspected vin, but was confused by the pin 30 reference. Ta .
M
