Hecho
Primero me da error al compilar porque dice que no conoce "toRoot" pero le he añadido el texto que pone en la pagina, en la linea 195 y justo antes del comienzo del texto de private:
void toRoot() {
setCurrent( &getRoot() );
Con la precaucion de que he copiado con el raton desde la web el texto y me ha añadido un caracter extraño (creo que es un retorno de carro) despues del parentesis, lo he borrado, y entonces he compilado y funcionando OK.
El fichero menubackend.h mio ha quedado asi:
|| @file MenuBackend.h
|| @version 1.4
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @contribution Adrian Brzezinski adrb@wp.pl, http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?action=viewprofile;username=vzhang
|| @description
|| | Provide an easy way of making menus
|| @license
|| | This library is free software; you can redistribute it and/or
|| | modify it under the terms of the GNU Lesser General Public
|| | License as published by the Free Software Foundation; version
|| | 2.1 of the License.
|| | This library is distributed in the hope that it will be useful,
|| | but WITHOUT ANY WARRANTY; without even the implied warranty of
|| | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
|| | Lesser General Public License for more details.
|| | You should have received a copy of the GNU Lesser General Public
|| | License along with this library; if not, write to the Free Software
|| | Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef MenuBackend_h
#define MenuBackend_h
A menu item will be a container for an item that is a part of a menu
Each such item has a logical position in the hierarchy as well as a text and maybe a mnemonic shortkey
class MenuItem {
public:
MenuItem(const char* itemName, char shortKey='\0' ) : name(itemName), shortkey(shortKey) {
before = right = after = left = 0;
//void use(){} //update some internal data / statistics
inline const char* getName() const { return name; }
inline const char getShortkey() const { return shortkey; }
inline const bool hasShortkey() const { return (shortkey!='\0'); }
inline void setBack(MenuItem *b) { back = b; }
inline MenuItem* getBack() const { return back; }
inline MenuItem* getBefore() const { return before; }
inline MenuItem* getRight() const { return right; }
inline MenuItem* getAfter() const { return after; }
inline MenuItem* getLeft() const { return left; }
MenuItem *moveBack() { return back; }
MenuItem *moveUp() {
if (before) { before->back = this; }
return before;
MenuItem *moveDown() {
if (after) { after->back = this; }
return after;
MenuItem *moveLeft() {
if (left) { left->back = this; }
return left;
MenuItem *moveRight() {
if (right) { right->back = this; }
return right;
//default vertical menu
MenuItem &add(MenuItem &mi) { return addAfter(mi); }
MenuItem &addBefore(MenuItem &mi) {
mi.after = this;
before = &mi;
if ( !mi.back ) mi.back = back;
return mi;
MenuItem &addRight(MenuItem &mi) {
mi.left = this;
right = &mi;
return mi;
MenuItem &addAfter(MenuItem &mi) {
mi.before = this;
after = &mi;
return mi;
MenuItem &addLeft(MenuItem &mi) {
mi.right = this;
left = &mi;
return mi;
protected:
const char* name;
const char shortkey;
MenuItem *before;
MenuItem *right;
MenuItem *after;
MenuItem *left;
MenuItem *back;
//no dependant inclusion of string or cstring
bool menuTestStrings(const char *a, const char *b) {
while (*a) { if (*a != *b) { return false; } b++; a++; }
return true;
bool operator==(MenuItem &lhs, char* test) {
return menuTestStrings(lhs.getName(),test);
bool operator==(const MenuItem &lhs, char* test) {
bool operator==(MenuItem &lhs, MenuItem &rhs) {
return menuTestStrings(lhs.getName(),rhs.getName());
bool operator==(const MenuItem &lhs, MenuItem &rhs) {
struct MenuChangeEvent {
const MenuItem &from;
const MenuItem &to;
struct MenuUseEvent {
const MenuItem &item;
typedef void (*cb_change)(MenuChangeEvent);
typedef void (*cb_use)(MenuUseEvent);
class MenuBackend {
public:
MenuBackend(cb_use menuUse, cb_change menuChange = 0) : root("MenuRoot") {
current = &root;
cb_menuChange = menuChange;
cb_menuUse = menuUse;
MenuItem &getRoot() {
return root;
MenuItem &getCurrent() {
return *current;
void moveBack() {
setCurrent(current->getBack());
void moveUp() {
setCurrent(current->moveUp());
void moveDown() {
setCurrent(current->moveDown());
void moveLeft() {
setCurrent(current->moveLeft());
void moveRight() {
setCurrent(current->moveRight());
void use(char shortkey)
recursiveSearch(shortkey,&root);
use();
void use() {
//current->use();
if (cb_menuUse) {
MenuUseEvent mue = { *current };
cb_menuUse(mue);
void toRoot() {
private:
void setCurrent( MenuItem *next ) {
if (next) {
if (cb_menuChange) {
MenuChangeEvent mce = { *current, *next };
(*cb_menuChange)(mce);
current = next;
void foundShortkeyItem(MenuItem *mi) {
mi->setBack(current);
current = mi;
char canSearch(const char shortkey, MenuItem *m) {
if (m==0) { return 0; }
else {
if (m->getShortkey()==shortkey) {
foundShortkeyItem(m);
return 1;
return -1;
void rSAfter(const char shortkey, MenuItem *m) {
if (canSearch(shortkey,m)!=1) {
rSAfter(shortkey, m->getAfter());
rSRight(shortkey, m->getRight());
rSLeft(shortkey, m->getLeft());
void rSRight(const char shortkey, MenuItem *m) {
rSBefore(shortkey, m->getBefore());
void rSLeft(const char shortkey, MenuItem *m) {
void rSBefore(const char shortkey, MenuItem *m) {
void recursiveSearch(const char shortkey, MenuItem *m) {
MenuItem root;
MenuItem *current;
cb_change cb_menuChange;
cb_use cb_menuUse;
#endif
Todo esto es con el ide 022 de arduino, y con la placa atmega 1280 seleccionada, no he probado con otro.
Si no consigues solucionarlo dimelo y me bajo el ide nuevo por si fuera eso.
Un saludo
PD: Añado, me costaba mas pensarlo que hacerlo, con el ide 1.0.1 y con placa arduino 328, arduino uno y arduino leonardo no da error al compilar, y con el ide 022 y placa 328 o atmega 1280 tampoco.
