Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Probleem met Hall Sensor  (Read 5141 times)
Offline Offline
Jr. Member
View Profile
even snel de gevraagde documenten. Nu ga ik mijzelf even verdiepen in je gegeven code.
Datasheet flowmeter:
http://www.produktinfo.conrad.com/datenblaetter/150000-174999/150392-da-01-ml-DURCHFLUSSM_FCH_M_POM_LC_ANSCHL_6MM_de_en.pdf
Datasheet oude hall sensor
https://iprototype.nl/docs/hall-effect-technische-datasheet.pdf
Datasheet huidige hall sensor
http://www.produktinfo.conrad.com/datenblaetter/500000-524999/505292-da-01-en-POSITIONSSENSOR_SS495A1.pdf
Logged
Offline Offline
Jr. Member
View Profile
Ik heb je code toegepast, deze werkt ook zoals de eerder gegeven code.
Ik heb alleen de flowmeter bekrachtigd (door er doorheen te blazen) Hierbij kreeg ik de volgende output.
start...
time: 500
rpmcount: 120
flowcount: 0
time: 7000
rpmcount: 0
flowcount: 0
time: 7500
rpmcount: 1080
flowcount: 8
time: 8000
rpmcount: 13080
flowcount: 110
time: 8500
rpmcount: 17880
flowcount: 149
time: 9000
rpmcount: 17400
flowcount: 145
time: 9500
rpmcount: 16800
flowcount: 140
time: 10000
rpmcount: 16320
flowcount: 136
time: 10500
rpmcount: 14760
flowcount: 123
time: 11000
rpmcount: 12000
flowcount: 100
time: 11500
rpmcount: 9960
flowcount: 83
time: 12000
rpmcount: 8280
flowcount: 69
time: 12500
rpmcount: 6840
flowcount: 57
time: 13000
rpmcount: 4920
flowcount: 41
time: 13500
rpmcount: 4320
flowcount: 35
time: 14000
rpmcount: 3600
flowcount: 31
time: 14500
rpmcount: 3240
flowcount: 26
time: 15000
rpmcount: 2640
flowcount: 22
time: 15500
rpmcount: 2160
flowcount: 18
time: 16000
rpmcount: 1680
flowcount: 14
time: 16500
rpmcount: 1200
flowcount: 11
time: 17000
rpmcount: 840
flowcount: 7
time: 17500
rpmcount: 360
flowcount: 3
time: 18000
rpmcount: 0
flowcount: 0
time: 18500
rpmcount: 0
flowcount: 0
"hall sensor bekrachtigd met een npool"
time: 216500
rpmcount: 0
flowcount: 0
time: 217000
rpmcount: 360
flowcount: 0
time: 217500
rpmcount: 480
flowcount: 0
time: 218000
rpmcount: 240
flowcount: 0
Quote
Dat klopt omdat dit mogelijk een concurrency race conditie veroorzaakt,
Het was mijn doel om met deltas te werken, Ik zal dat in de onderstaande code proberen correct te doen.
Wat is een concurrency race conditie?
Als ik de deltas in de code zie, dan kan ik die vergelijken met een soort van "blink without delay" code. Dus die verschillende variabelen kan ik mijn code beheersbaarder maken door jouw delta manier toe te passen.
Beide sensoren zijn voorzien van een pull up (5V-output) weerstand van 10k
de honeywell heeft een gevoeligheid van 3-3.25mV/ Gaus??
de oude heeft een gevoeligheid van 0,5 mT?
« Last Edit: November 04, 2012, 01:24:49 pm by Nald » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
De deltaRPM i shet aantal pulsen in het laatste interval.
(1) unsigned long deltaRPM = rpmHV - lastRPM;     // deltaRPM is de huidige waarde van de teller - de vorige waarde
Dit aantal pulsen wordt dus in INTERVAL milliseconden gemaakt. Dit moet omgerekend worden naar omwentelingen per minuut. om dit te doen wordt het aantal vermenigvuldigd met 60000 (het aantal milliseconden in een minuut en gedeeld door de lengte van het INTERVAL. Als je de waarde van INTERVAL veranderd dan blijft deze formule kloppen omdat het gemeten interval ook dito korter wordt. Door het werken met delta kan de interrupt gewoon doortellen en zul je geen puls missen.
(2) Serial.println(deltaRPM * 60000UL/INTERVAL);
hoog de waarde van de vorige waarde op met de delta om de "huidige" RPM teller waarde te krijgen.
(3) lastRPM += deltaRPM;
Let op! Je mag hier niet zomaar zeggen    lastRPM = RPM
want in de tijd tussen het executeren van regel (1) en regel (3) kunnen er alweer nieuwe pulsen zijn binnengekomen. Dit is een concurrency race conditie is. Doordat de interrupt in de achtergrond afgehandeld wordt heeft deze een andere waarde gekregen. NOg een voorbeeld maar dan met op nul zetten:
(assume RPM = 100)
(1) count = RPM;
(2) berekeningen met count.
(3) RPM = 0;
Nu kan tussen regel (1) en (3) de waarde van RPM opgehoogt zijn in de interrupt en dan zet je hem op 0 waardoor je pulsen mist.
Het kan nog kritischer , stel je hebt de formule
X = RPM + RPM;
dan kan de waarde van RPM veranderen net tijdens het uitrekenen van de formule met als gevolg dat X geen even getal is.
De output ziet ervreemd uit, de waarden komen perfect overeen, maar zouden 2 verschillende interrupts moeten zijn. NU lopen ze synchroon terwijl het 2 sensoren zijn. Heb je ergens een kortsluiting of heb je bewust beide ingangen 2,3 gekoppeld?
bv
rpmcount: 16800
flowcount: 140
140 * 60000 / 500 = 16800
sofar,
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Jr. Member
View Profile
Dank je voor je heldere uitleg.
Ja ze lopen inderdaad gelijk op, maar alleen met de nieuwe sensor, bij de oude is dit niet. Ik heb bij conrad de gevoeligste gekocht. Ik heb misschien het idee, dat als ik de flowsensor bekrachtig dat er dan elke keer een minimale daling is in de voeding en dat de hall sensor hier op reageert.
De hall sensor reageert immers alleen op de flowsensor en niet andersom (zie laatste metingen)
Verder kan ik nergens een kortsluiting vinden.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Klinkt aannemelijk,
De pull up zit zo?
+5V ----[ 10K ]-----Arduinopin3 ------+hall+---- GND (0V)
Logged
Rob Tillaart
Offline Offline
Jr. Member
View Profile
ik heb hem zo
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Zou dit betekenen dat dit een analoge sensor is?
Quote
En dit een digitale?
10.000 Gauss = 1 Tesla ==>  0.5 mT = 5 Gauss
Wordt de Hall sensor warm als ie aangesloten is?
IK duik even indedatatsheets/
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
from - http://bildr.org/2011/04/ -
Quote
Melexis US1881
The Melexis US1881 (available from sparkfun at $0.95) is a Latching Hall Effect Sensor meaning that once it is triggered it latches and will not unlatch until a magnetic force of reverse polarity and strength is sensed. So If the north pole of a magnet turned it on, the south pole of a magnet is then needed to turn it off. When the US1881 is triggered the output will be equal to the source voltage (3.5 to 24V) and unlatched will output 0v/ground.
I did find that using an overly strong magnet with this sensor would sometimes not latch it or would latch it to the point that it was hard to unlatch. So keep your 1in rare earth magnets away from this one.
Als ik dit lees lijkt het me een minder geschikte sensor om een voorbijgaand magnetisch veld te detecteren omdat je een tegenovergesteld magnetisch veld nodig hebt om hem terug te zetten. De vraag is of dat je in jouw meetopstelling een 2 magneet hebt die tegenovergesteld gericht staat.
PS, Aansluiting ziet er op zich OK uit.
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
De 2e Hall sensor geeft volgens mij een analoge uitgangsspanning afhankelijk van het magnetisch veld. 3mV/Gauss klinkt dan betekenisvol.
DIt zou je met een VOltmeter moeten kunnen verifieren. Kun je dat doen?
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
from - http://sensing.honeywell.com/index.php?ci_id=3108&la_id=1&pr_id=36221&utm_source=supplyFrame&utm_medium=SEP -
Quote
SS490 Series MRL (Miniature Ratiometric Linear) sensors have a ratiometric output voltage, set by the supply voltage. It varies in proportion to the strength of the magnetic field.
A new Hall effect integrated circuit chip provides increased temperature stability and sensitivity. Laser trimmed thin film resistors on the chip provide high accuracy and temperature compensation to reduce null and gain shift over temperature. The quad Hall sensing element minimizes the effects of mechanical or thermal stress on the output. The positive temperature coefficient of the sensitivity helps compensate for the negative temperature coefficients of low cost magnets, providing a robust design over a wide temperature range.
dus een analoge uitgang.
Logged
Rob Tillaart
Offline Offline
Jr. Member
View Profile
klopt de honeywell is een analoge. Dit heb ik ook gemeten met de proefcode van arduino tutorials. Geen magneet een veranderende waarde tussen de 506-512, wanneer de noordpool langskomt gaat hij richting de 0 (hoe dichterbij hoe lager de waarde), bij een z-pool gaat hij richting de 1023 (hoe dichterbij hoe hoger de waarde). (is het nu nog steeds nuttig dit na te meten met een voltmeter?)
De oude(melexis) heeft inderdaad een z-pool nodig om te resetten, alleen de schijf die ik gekocht heb, heeft alleen maar N-polen naar buiten gericht. En die schijf was behoorlijk duur, dus had besloten de sensor te vervangen. (door de honeywell) De melexis heeft inderdaad maar 2 standen: 0 of 1023.
de hall sensor wordt naar mijn weten niet warm.
als ik verder lees bij bildr.org kan ik dan niet beter deze aanschaffen?  OPTEK Technology OH090U
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
nee, het analoge gedrag is nu inmiddels wel duidelijk smiley
Quote
Dit is ~2.5 Volt, en dat is voor de digitale IO lijn (de interrupt lijn) een ongedefineerde waarde, soms 0 soms 1 dus ik kan me voorstellen dat het gevoelig is voor externe signalen. Dit verklaart volgens mij het gedrag van je systeem.
Om een nette puls te krijgen voor de IRQ lijn je dit analoge signaal omzetten in een 0V - 5V signaal. Nu ben ik geen electronicus maar ik denk dat je met de analoge Hall sensor een transistor moet schakelen, zodat die een bepaalde drempelwaarde "geleid" als een schakelaar.
Kan iemand met meer E kennis details geven van een dergelijke schakeling?
Logged
Rob Tillaart
Offline Offline
Jr. Member
View Profile
@ robtillaart.
Nogmaals bedankt voor al je geboden hulp, via het engelse draadje kwam iemand met de tip om toch voor een andere sensor te gaan , dit ga ik ook doen.
Maar ik ben ook bezig om die specifieke stukken code toe te passen die jij voorgesteld hebt, alleen hier heb ik nog een paar vraagjes over:
Code:
if (now - lastTime >= INTERVAL)
is dit bestand tegen de overflow, dit omdat ik het systeem zo maak dat hij het hele jaar bekrachtigd wordt.
of is dit beter?
Code:
(long)(now-millishv) >=0)
Ook werk jij met deltaRPM, op den duur gaat ook de RPM/Flow telling in de overflow krijg ik hier last van met de delta formule?
Ik ga uit van deze code:
Code:
//    FILE: RPM DEMO.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-NOV-04
// PUPROSE: demonstrate the use of interrupts to build an RPM measure tool
// initialize vars while declaring
volatile unsigned long rpmHV = 0;
volatile unsigned long flowHV = 0;
unsigned long lastRPM = 0;
unsigned long lastFLOW = 0;
unsigned long lastTime = 0;
#define INTERVAL 500UL  // unsigned long as all timing math is done in UL.
  attachInterrupt(1, rpm_fun, RISING);
  attachInterrupt(0, flow_fun, RISING);
  Serial.println("start...");
  unsigned long now = millis();  // to prevent that the next read of millis jumps a few millisecs
  if (now - lastTime >= INTERVAL)   // every 500 milliseconds
    lastTime = now;  // remember last time we displayed something
    // how many pulses since last display action
    unsigned long deltaFLOW = flowHV - lastFLOW;
    // display the current values
    Serial.print("time: ");
    Serial.println(now);
    Serial.print("rpmcount: ");
    Serial.println((deltaRPM * 60000UL) /INTERVAL);
    Serial.print("flowcount: ");
    Serial.println(deltaFLOW );   // needs probably some math to
    // adjust the last values
    lastFLOW += deltaFLOW;
void rpm_fun()
  rpmHV++;
void flow_fun()
  flowHV++;
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Code:
of is dit beter?
Code:
Dit kun je gewoon uitproberen door een test sketch te schrijven. Het eerste is bestand tegen overflow, dat weet ik, de 2e constructie heb ik nooit geprobeerd.
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Omdat de deltas iedere keer opnieuw worden uitgerekend tov de vorige waarde zal er geen overflow zijn.
even modulo 10 :     9-8=1    0-8=2     1-8=3     2-8=4 etc
Logged
Rob Tillaart
Pages: 1 [2] 3   Go Up
Print
Jump to:
