Loading...
Pages: [1]   Go Down
Author Topic: Power for Relay Board  (Read 756 times)
Winston-Salem
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
I actually have an 8 channel relay board
http://www.amazon.com/dp/B006J4G45G/ref=pe_175190_21431760_M3T1_ST1_dp_1
but this picture illustrates what I am looking at doing. I am another person that doesn't know enough about this environment to even know where to look for answers. I hope that you can help.
I read that this board allowed for electrical isolation from the Arduino board only if it has its own 5V power source. Also, since many cables come in 8 wire configurations, I thought that I could move the VCC (5V) and the ground lines to an external power source.
My thinking was to break open a wall wart and connect it to a 3 pronged plug, which includes a ground. I'm not completely sure about wiring here because the relay board requires a VCC and a ground wire and the wall wart typically has just the 2 AC plugs.
I also thought that I would use a USB cable or a phone type jack and cable but I don't know if they would carry enough current to do the switching. perhaps some other cable would be better.
Can anyone please help me with this?
Logged
I have an Arduino Mega 2560. I also have a (pH) BNC Sensor Shield,an I2C/SPI/Onewire Shield(I beleive that it an on board clock.)and a Breakout Board Shield, all three are from Andrew Oke. Additionally, I have a Stepping Motor but could certainly buy a Servo Motor instead if it is any better for what I want to do, short term/long term. Trying to read the lable, I guess that it is: Type 57BYG. 12 V/Phase, 20ohm, 0-6A/Phase 1.8 Deg/Step, No. 04052 with a K179 Stepper Driver board attached. I can't confirm that the board is fully funtional
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Well that specific relay board you linked to is a solid-state relay board designed to switch higher voltage AC loads on and off via it's output connections. Being that is uses SSRs as it's switching elements they already have opto isolation internal to the small back SSRs on the board, so I see no safety benefit or reason you should try and power the relay board with an independent +5vdc power source. Just complete the dotted red line connection to the arduino's shield 5V pin and be done with it and ditch the external DC power supply.
Lefty
PS: Here is a E-bay listing for the same board which down the page has a partial schematic drawing (of a single channel) showing the logic and use of the DC power, ground, and signal input wiring.
http://www.ebay.com/itm/SainSmart-8-Channel-5V-Solid-State-Relay-Module-Board-OMRON-SSR-AVR-DSP-Arduino-/280825893280?pt=LH_DefaultDomain_0&hash=item41628711a0
« Last Edit: November 07, 2012, 12:40:19 pm by retrolefty » Logged
Winston-Salem
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Thank you for answering. OK so if I stick with a standard setup, how about using standard cables like phone, USB style computer or some other style cables? I would like to stay away from D style connector. I guess that I will need 10 lines for 8 channels.
« Last Edit: November 07, 2012, 07:16:27 pm by Asa Herring » Logged
Offline Offline
Brattain Member
View Profile
Sure, assuming we aren't talking particular long cable runs (say a couple of feet or less) you should be free to use any cabling you want as we are talking low voltage low current on the arduino side. Now the wiring you use on the switching high voltage AC should be selected for proper voltage and current rating for the service you are using it in.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
