Topic: Motion activated MP3 trigger using PIR ,UNO MP3 Trigger (Read 3564 times) previous topic - next topic
firsttimehelp
Nov 01, 2012, 10:18 am Last Edit: Nov 01, 2012, 10:21 am by firsttimehelp Reason: 1
Hi everyone,this is my first time using Arduino and I have no experince in C programming,my project is using a PIR sensor to detect motion and send a signal to arduino UNO which will then send a signals to the MP3 Trigger which will then play couple of songs. Those any1 have any codes I can use??urgent help required
PaulS
When is our homework due?
firsttimehelp
PaulS
is it enough time?
Depends on how adept you prove to be writing code. Reading a PIR isn't difficult. Triggering an MP3, with the appropriate shield, is easy. Without a shield, it's plain impossible.
Borrowing someone else's code is not going to do you any good, unless it is for the SAME hardware you have, arranged the same way. The odds of that happening are pretty slim.
Even if if did, what would you have learned? Why are you taking this class, if it isn't to learn?
Bainesbunch
#4
Nov 01, 2012, 07:25 pm Last Edit: Nov 01, 2012, 07:29 pm by Bainesbunch Reason: 1
I'll take your money  XD
Seriously though like Paul said. Why not learn how to do it.
I mean what use are you going to be to an employer designing stuff if all you ever do is buy the design from someone else. They could do that themselves and cut out the middle man.
For the Audio use one of these VS1000 Audio Module http://www.vlsi.fi/en/products/vs1000module.html only $20 and the cost of an uSD card and all programmable using serial commands through the serial port with a nice 5v power rail and TTL level UART
Cheers Pete.
EmbeddedAT .. From Concept to Prototype to Production
Electronics and firmware design and project mentoring
I do answer personal requests for help when accompanied with a PayPal receipt ;)
firsttimehelp
I'm not studying C programming at all in my modules,but I joined a group for my engineering fair project which seemed relatively easy till we go to the programming part,I have the codes for the PIR to the UNO,it's just the audio part that stumps me,can I use this instead of the MP3 trigger http://www.myduino.com/index.php?route=product/product&path=49&product_id=299?
PaulS
Yes. There is even sample code to go with it,
