Loading...
Pages: 1 [2]   Go Down
Author Topic: Current sensing for buck boost converter  (Read 1365 times)
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
[ The hall sensor mentioned above is ACS712, not ACH712 BTW. ]
If you have a SMPS like this you have to be really careful to shutdown the switch fast if the current goes too high - or else
use a large inductor (slower switching required, more safety margin for saturation).
If the current rises high enough to saturate the inductor then the inductor then just becomes a short-circuit and the current
will slam up to perhaps 10's of amps in a few microseconds or so and blow the MOSFET before the opamp can respond, and certainly
far faster than analogRead()'s 110us execution time.
You would normally use a fast comparator to monitor for this severe overcurrent condition - sub-microsecond response is
good here.  Once you have that you might as well let it do the regulation too...
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
See attached peak detector schematic. R1 is the current sense resistor. (R2 + R3)/R2 defines the op amp gain, and C1 * (R2 + R3) defines the time constant, which should be large compared to 1/f where f is the PWM frequency.
Ok !
So if I want to get the voltage value of Rsense I have to integrate the diode drop voltage  ?
Basically :
Vc1 = Vr1 * gain - Vdrop
Otherwise my Ir1 evaluation will be lowered by a 0,7v factor !
Is that  right ?
No, the circuit is designed (i.e. op amp feedback resistor taken from the cathode of the diode) so that the diode voltage drop does not enter the equation.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Newbie
oops
View Profile
hi !
I finally read a lot on OPAMP because many values seen on tech-doc were completely unknown for me.
My choice for the op-amp is now Maxim MAX4167, this one is a rail to rail input and output op-amp ! While the input can vary from 0.0165V to 0.33V the rail to rail input aspect is very important. The MAX4167 have a 0.25mV-0.85mV Input Offset Voltage so my input voltage will be correctly processed. The Gain-Bandwith is around 36Mhz (input is 170Khz)
My problem is the op-amp gain. I use a non inverting amplifier so Vout = (1+(R2/R1))Vin
With a digital multimeter (and with arduino ADC), I sense a  ~0.010V voltage. On the opamp output, voltage is "only" ~0.016V... Something is wrong somewhere because i expect somewhat x10 ? I double check R1 & R2 value everything seem to be okay.
What wrong with this ?
I can attach a photo of the breadboard if you need !
Thanks for your help.
BR
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
