Author Topic: How to leave an LED on  (Read 365 times)
Hello guys, I am probably gonna get laughed at here but I need help programming an LED. I got the SUPER basic program on turning an LED on when a pushbutton on my breadboard is pressed but the LED only turns on when I press it, and it goes off when I release it. I need a program where I press and release it once and the LED turns (and remains) on. And when I press and release it again the LED goes off. I am using an Arduino UNO.
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, LOW);
  else {
    // turn LED off:
    digitalWrite(ledPin, HIGH);
UK
Online Online
The key phrase here is:
You need to detect when the button goes from "pressed" to "not pressed" and simply flip the state of the LED.
Cape Town South Africa
A newbie with loads of posts, and still so much to learn !
Normally the button would be between a pin ( set with a pullup in setup )  and ground,
so if you press the button and digitalRead the pin it will be low,
    // turn LED on:
Normally the LED is wired from the pin through a resistor to ground ( as is the built in LED on pin 13 )  so you would
digitalWrite(ledPin, HIGH)  to switch it on
    // turn LED on:
  else {
    // turn LED off:
even when you get the logic sorted out, what you are doing is saying " if the buttons is pressed, light the LED' else ( otherwise ) turn it off.
So you might as well wire the LED to the button :-)
 when you have the logic levels sorted search for toggle.
We live in the era of the smart phones and stupid people.
Thanks for the help. Hopefully I can figure this out. Kinda confused cos I'm used to programming 8051s on Silicon Labs.
UK
Online Online
8051, PIC, PowerPC or ARM - the principle is identical.
New York
xronosclock.com
Here's a great video tutorial that will show you just what you need smiley
https://www.youtube.com/watch?v=_LCCGFSMOr4
Towards middle of it it shows how to switch on/off button so it stays lit or unlit.
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, and purchasing info smiley
